GPS to Laptop
Submitted: Sunday, Feb 11, 2007 at 16:18
ThreadID: 42197 Views:3848 Replies:5 FollowUps:6
Does anybody know of a person or company that is able to configure a Magellan GPS to a laptop. I am IT challenged to many abbreviations.
Deano
Reply By: Andrew from Vivid Adventures - Sunday, Feb 11, 2007 at 17:27
drop me a note deano if you are around Adelaide metro ...
AnswerID: 221100
Follow Up By: mfewster - Sunday, Feb 11, 2007 at 20:06
Hi Andrew
I have an early model Magellan (pre mapping software) Is it possible to link these, using the GPS reading, to mapping software on a laptop?
Apart from that, I will give you a ring sometime soon. We wont be doing the Simpson trip with Heinz this year, he is too busy with work.
Mike
FollowupID: 481840
Follow Up By: Andrew from Vivid Adventures - Sunday, Feb 11, 2007 at 20:59
Hi Mike,
Which model Magellan do you have?
Sorry to hear about Heinz ... are you going to offer to take anyone else?
Andrew.
FollowupID: 481850
Follow Up By: mfewster - Monday, Feb 12, 2007 at 08:26
Good morning Andrew
I have a Magellan 4000XL with an external aerial up on top of the snorkel.
We are still thinking about whether or not we will do the race this year. I'll give you a phone call.
Thanks also Navarman. I am in south Adelaide but as I know Andrew I will impose on his generosity first.
FollowupID: 481906
Follow Up By: Andrew from Vivid Adventures - Monday, Feb 12, 2007 at 12:26
Do you have the 12V interface module that includes a DB9 connector? (a 9-plug connector in a D-shape).
Andrew.
FollowupID: 481932
Follow Up By: mfewster - Monday, Feb 12, 2007 at 12:38
I think have one of those. It also allows me to connect to 12V without having to use the batteries?? Is that the gaddie?
FollowupID: 481933
Reply By: bardenboy - Sunday, Feb 11, 2007 at 19:17
Try GPSOZ, located in Sydney and nows his stuff
checkout www.gpsoz.com.au
Good Luck
Dennis
AnswerID: 221122
Follow Up By: DeanoSA - Sunday, Feb 11, 2007 at 19:51
Thank you
Dean
FollowupID: 481834
Reply By: The Explorer - Sunday, Feb 11, 2007 at 20:10
Hello - What model of Magellan and what are the spec's of the laptop.
AnswerID: 221135
Reply By: navaraman - Sunday, Feb 11, 2007 at 20:53
I'm in Adelaide (south) Deano and using a Magellan Meridien, be happy to try and help id needed.
Patrolman Pat
AnswerID: 221147
Reply By: Member - andrew G (VIC) - Monday, Feb 12, 2007 at 15:49
Hi we are using base model maggelan to a laptop, the only real hassle is oxeploere map software using the same com port as gps Sounds complicated but isnt really. just have to check the port the laptop chooses and tell ozexplore which port.This might put you in the right direction. Nothing else needed to be done when i connected ours.
AnswerID: 221246
