Thomas T58 winch
Submitted: Sunday, Feb 11, 2007 at 17:05
Member - Alastair D (NSW)
I finally decided that I needed to service my elderly but still very functional Thomas winch. Heavy but has a lot of grunt. Stripped it down and no problems beyond a lot of grit and grime where it should not be.
Had a minor oil leak so I resealed the plate and now I need to top up the oil. So long since I did it before can't remember what type of oil to use. The stuff in it is dark pink and smells like hypoid.
Any suggestions or do I contact Thomas Winch Co in Qld? Not sure they are the same crowd as I haven't seen Thomas 4wd
winches on the market for years.
alastair
Reply By: Peter 2 - Sunday, Feb 11, 2007 at 18:24
In my EW8000 the electric motor gearbox takes ATF through the 1/4" allen key headed plug at the front of the gearbox and the worm box takes B140 grade according to the owners manual.
221109
Reply By: luch - Monday, Feb 12, 2007 at 19:00
Use Auto Trans Fluid (ATF Dextron III)
Im sure these
winches are still in production as Parks Victoria still use them on some Landcruiser trays
221277
