Help identifying a part please
Submitted: Monday, Feb 12, 2007 at 19:13
ThreadID: 42232 Views:2702 Replies:8 FollowUps:12
Hello all,
I have a dilema. I need to identify the name of the part shown in this pic:
!MPG:4!
it is on the injector pump of the 4JBT-1 2.8 td. It is to do with the advanced timing for the pump. I Have scoured my manual from start to finish, but am unable to find it referenced anywhere.
I hope someone can help.
Mike
Reply By: Member - John (Vic) - Monday, Feb 12, 2007 at 19:30
Thats easy everyone knows what that thing is!!!
Its a "Jigger", always found in conjunction with "thing a me bobs", easy as ;-)
AnswerID: 221282
Follow Up By: mike w (WA) - Monday, Feb 12, 2007 at 19:42
Are, YES!! thats connected to the whatsa-mejooger, which in turn activates the thinga-me-jig.
Silly me ;)
FollowupID: 482014
Follow Up By: Member - John (Vic) - Monday, Feb 12, 2007 at 19:48
Thats it Mike, Problem solved as I said "Easy As"
Glad I could help!! ;-)
FollowupID: 482018
Follow Up By: Member - Jay Gee (WA) - Monday, Feb 12, 2007 at 19:52
I disagree - I think it's a watch-a-macallit that goes to a thing-a-ma-gig
FollowupID: 482019
Follow Up By: Member - John (Vic) - Monday, Feb 12, 2007 at 20:01
It can't be as Jeeps don't have such components so how could you even guess what it was??
Jeeps are only fitted with Hot Dogs as the perfect US of A invention.
FollowupID: 482022
Follow Up By: Member - Ed. C. (QLD) - Monday, Feb 12, 2007 at 20:07
Bugga!!!
Looked at that pic, and thought "Ah yes, the Doo-Hickey Thingy"....
Looks like I was wrong:-(((
Just goes to show.... Ya never stops learnin'
Confucius say.....
FollowupID: 482024
Follow Up By: Alloy c/t - Monday, Feb 12, 2007 at 20:32
The proper term for the pictured item is " screw me in too hard and the poo will hit the fan big time dohicky " bleeding amatures ,don't even know a big time stuffup valve when they see one !
FollowupID: 482031
Follow Up By: Member - steve H (QLD) - Monday, Feb 12, 2007 at 21:34
Its the thingo that now you have seen it you will worry when it going to break. You need to have a spare one now.
FollowupID: 482056
Follow Up By: mike w (WA) - Monday, Feb 12, 2007 at 21:41
Thanks gang, I knew I could count on you! LOL
FollowupID: 482058
Follow Up By: Member - Julie P (VIC) - Thursday, Feb 15, 2007 at 20:22
A wigwam for a gooses bridle????
jules
FollowupID: 482731
Reply By: Sparkie C - Monday, Feb 12, 2007 at 20:36
It looks like it is a fuel cut off solenoid it is about the correct location and size but i'm a bushy and can always be wrong.
Hope it helps
Sparkie.
AnswerID: 221287
Reply By: Bonz (Vic) - Monday, Feb 12, 2007 at 20:49
Just had a look at the GU on Disk thingummybob I have and I can see it on the side of the injector pump but cant find any reference to it, sorry
AnswerID: 221293
Reply By: Member - Olcoolone (SA) - Monday, Feb 12, 2007 at 20:51
Its a fuel cut solinoid, when you turn the vehicle off it stops fuel to the rack so you dont get run on.
Regards Richard
AnswerID: 221295
Reply By: luch - Monday, Feb 12, 2007 at 21:02
Fuel cut off solinoid
Why do you need to know ?
Think it may be a problem ?
or
you just want to know what it is ?
AnswerID: 221298
Just doing some research. Had the injectors cleaned today due to some ongoing issues with performance- turns out two injectors were blocked. Mechanic mentioned if that did not fix the symptoms, this was the next option, apparently quite common on this model pump. Internals bugger up, being an electronic thigo- bob (putting those tech terms to use here), and can cause symptoms such as light smoke on start up, rough idle when cold. Im intrigued by it being used for fuel cut off, as I though it had something to do with the advance timing, as I have been told by 3 diesel mechanics?
Perhaps a similar looking doohiky does different things on different vehicles.
Thanks to all those that have 'helped' (term used VERY loosely LOL) Its always good fun ;)
FollowupID: 482057
Reply By: mike w (WA) - Monday, Feb 12, 2007 at 22:12
Okay, here we go. First thanks to all those that have replied.
Second. being armed with some information (dangerous, I know), Ive reviewed the manual and the diagrams that they have for injector pumps to suit the 4JB series and I can confirm the part in question is NOT a fuel cut off valve. On the model pump in question, the fuel cut off is mounted vertically, whereas this part is mounted horizontally.
Not to matter tho, we have eliminated one pesky culprit.
So, any further advances on what theis doohiky may be, or is it a thinga ma gig???
AnswerID: 221317
Reply By: Member - Matt Mu (Perth-WA) - Monday, Feb 12, 2007 at 22:31
You are very right it does advance the fuel timing during warm up etc. You can check to see if is working by breaking the connection at the thermostat with the bullet connection (orange temp wire?). You will hear the relays clicking on the dvs side of the engine bay and a slight change in engine note.
If you leave it disconnected you will have a VERY noticeable knock...more than usual I know 4Jb1T are noisy!
I found mine ran better disconnected for awhile but after running 3 tanks (300litre) with Gull Bio D the solenoid cleaned and started working and now runs much better. (this was all just after purchase)
Still going to do the injectors though and have a slight drain back problem from idle...it sounds like its missing at idle and takes a minute to idle well but if you pump the bleeder before you start it idles from cold like a dream....not too concerned but will sort it out over time.
Just glad its cleaning itself out and with a few adjustments its pulling harder and harder, just about gotten rid of the huge lag!! I will fit the intercooler and cut and fit the bonnet scoop (so it looks like a 2002 3.0l Rodeo) then get it dyno tuned!
Matt.
AnswerID: 221321
Follow Up By: mike w (WA) - Monday, Feb 12, 2007 at 23:05
Thanks Matt Mu.
I shall check it out during the week.
The Gull Bio D does work a treat. Ive been running bio fuel for just over 12 months now, and I tell you I notice the difference if it runs on anything else.
I rectified some of my drain back issue with installation of a one way valve, and also replaced the separator and filter with a cav system from denco. This also freed up enough room to fit a second battery of N70 size under the bonnet with a very minor mod to the power steering reservoir. But cold start is still a problem
Id be interested to know what you did to get rid of your lag, im getting ready to fit a boost adjuster and to wind the boost up a smidge.
FollowupID: 482076
Follow Up By: Member - Matt Mu (Perth-WA) - Tuesday, Feb 13, 2007 at 10:05
Yes boost has been adjusted a little, but also have adjusted the amount of extra delivery from the boost-compensator when boost hits. No use giving it more air and no more fuel or more fuel and no more air!
Goodluck with it.
Matt.
FollowupID: 482136
Reply By: Member - extfilm (NSW) - Monday, Feb 12, 2007 at 23:00
Without seeing the bigger picture, to me it looks like some sort of fuel flow sensor.....
AnswerID: 221327
