Site Search
Section Image
triton lemon or buy of the year
Submitted: Saturday, Apr 05, 2003 at 08:16
jonny dontknowmuch
just bought a second hand 99 model 3l 4wd triton. the thrust bearing seems to make heaps of noise so loud i can hear it standing next to the drivers seat (outside) when theres no other noise around. spoke to heaps of mitsubishi service centres 50% would of said no thats not right 50% would of said no worries thats the norm. also its just developed a knocking noise somewhere in the back when under way i carnt pick a trend sometimes when slowing sometimes when speeding up no a regular timed one either. other than that great rig i just wanna get these problems ironed out before taking it anywhere.
any input would be great.
ThreadID: 4227 Replies: 7
Views: 476 FollowUps: 9
AnswerID: 16914   Submitted: Saturday, Apr 05, 2003 at 09:11
sloth replied:
the knocking noise could be a rear uni, happened to me that way once with an old ute i had (holden).
I would say thrust bearing noise is not normal, especially if it goes away when you depress clutch.
Reply 1 of 7
FollowupID: 10532   Submitted: Saturday, Apr 05, 2003 at 12:51
jonny dontknowmuch posted:
thanks sloth the thrust bearing noise does go when i depress the clutch!
FollowUp 1 of 7
FollowupID: 10539   Submitted: Saturday, Apr 05, 2003 at 17:33
Rowdy posted:
I was always of the opinion that if the bearing noise went away when the clutch pedal was depressed that the problem was the front bearing on the input shaft of the gearbox.
Rowdy
FollowUp 2 of 7
FollowupID: 10555   Submitted: Saturday, Apr 05, 2003 at 22:09
Member - Allan posted:
Jonny, if the noise stops as soon as you apply slight pressure on the clutch it could be the return springs on the clutch fork. No sure if your one has one but I had a vehicle that had a thrust bearing that rattled with the foot off the clutch. It was a broken return spring. If the bearing noise stops when you have fully depressed the clutch and the input shaft has stoped spinning then it will be the bearings on the imput shaft.Nearly as good as sex
FollowUp 3 of 7
FollowupID: 10559   Submitted: Sunday, Apr 06, 2003 at 00:46
zigglemeister posted:
I'm with sloth, I always thought that a noise that goes away when you step on the clutch is most likely to be the thrust bearing. I think it's because they tend to go dry, and get a bit loose and rattly, but when you step on the clutch you load them up and so the noise reduces or goes away completely. But I could be wrong...
FollowUp 4 of 7
FollowupID: 10560   Submitted: Sunday, Apr 06, 2003 at 00:48
sloth posted:
i could be too....
FollowUp 5 of 7
FollowupID: 10562   Submitted: Sunday, Apr 06, 2003 at 01:15
I think we all go that way - go dry and get a bit loose & rattly.
Anyway I don't think it should necessarily be accepted as 'normal'. Sounds like time to slip the gear box out and check the thrust bearing and if that is OK look at the input shaft brgs. Nearly as good as sex
FollowUp 6 of 7
FollowupID: 10563   Submitted: Sunday, Apr 06, 2003 at 01:21
sloth posted:
life that is, Allan.
FollowUp 7 of 7
AnswerID: 16924   Submitted: Saturday, Apr 05, 2003 at 13:46
Kev. replied:
Could the knocking be the exhast ?
I dont know what the triton 31 is but if its a ute it could be the ute body to chassis bolts come loose and jumping on the mounts (this happened to my old Hilux).
Reply 2 of 7
AnswerID: 16946   Submitted: Saturday, Apr 05, 2003 at 22:10
Eric replied:
Jonny,
Congratulations on the new beast, sounds like you need to check the oil in the gear box. If there is any sign of water in the oil the ute has been driven in water and you should change the oil in everything and rerace the box. The gear box bearings should last if they are in clean oil. The knock could be uni's, shackle bushes, spare tyre, loose wheel nuts, good luck. Eric.
Reply 3 of 7
AnswerID: 16990   Submitted: Sunday, Apr 06, 2003 at 19:29
jason replied:
had a mazda bravo with a noisey thrust bearing.my 4wd mechanic told me it was probably just a little dry and suggested i spray inox on the bearing through the inspection hole.worked a treat! noise went away drove another 20000 km's and sold it and know one knew the difference.keep in mind you must use the little nozzle extensions and be accurate.you don't want any on the clutch plate.also don't use to much because you don't want it spraying of everywhere.
noise in the back end sounds like a uni joint on it's way out.
hope it helps
jason
Reply 4 of 7
Activities Index
Great Barrier Reef and Kuranda 2 Day Package Great Barrier Reef and Kuranda 2 Day Package
Cairns and Tropical North QLD - QLD
Discover the Great Barrier Reef as you join our luxury day cruise to the outer edge by fast, air-con
Fly Fishing Full Day for 2 Fly Fishing Full Day for 2
Snowy Mountains / Jindabyne - NSW
Fly Fishing is a great way to fish and there is nothing more relaxing than standing in a stream cast
Morning Single Sea Kayak Eco Adventure Morning Single Sea Kayak Eco Adventure
Townsville Region - QLD
Enjoy the tranquillity of a kayak around beautiful Magnetic Island in a single kayak.
Sea Kayak Half Day - Melbourne (St Kilda) Sea Kayak Half Day - Melbourne (St Kilda)
Melbourne - VIC
Do you enjoy the great outdoors? Then try your hand at a half day sea kayak journey.
Book Now - Things To Do
AnswerID: 17052   Submitted: Monday, Apr 07, 2003 at 15:06
jonny dontknowmuch replied:
thanks for all the replies im taking it to the mitsu place up the road and see what he says.
i feel like an idiot though as the noise was my spare jiggleing in the back.
anything else i should know about the tritons?
Reply 5 of 7
AnswerID: 17058   Submitted: Monday, Apr 07, 2003 at 16:27
Wombat replied:
Jonny,
Congratulations on purchasing what I believe is a great (underated) 4WD. I have just taken delivery of our second new GLS dual cab (traded in our 99 model) and can offer the following from our experiences.
The thrust bearing on EVERY 5 speed Triton that I know of is noisy. I queried this at first service on the first vehicle to be told that the sound was normal. I continued to query it at each subsequent service and the standard answer didn't change. When we traded it the noise was still there BUT we didn't ever have any trouble with it.
AND the new car has exactly the same noise.
You'll be happy to know that we didn't have any mechanical breakdowns in the entire time that we had the truck.
Let me know if you get a Mitsubishi dealer to do anything about the noise - or explain what they believe it is.
BTW, where did you buy it, how many k's and how much did they sting you?
Reply 6 of 7
FollowupID: 10695   Submitted: Tuesday, Apr 08, 2003 at 16:37
Wombat thanks for the reply yours was the one i was after (no offence inteded to all the other replies though).
bought it from a non mitsu dealer at homebush sydney it was 35000 with 66000 on it. it only has a few extras like cd roof racks and cruise control. bit pricey but its what we wanted and we looked all through sydney that weekend and couldnt find any better.
once again thanks for your input now i can sleep again.
FollowUp 1 of 2
FollowupID: 10704   Submitted: Tuesday, Apr 08, 2003 at 17:52
Wombat posted:
Jonny,
Glad to be a help.
A question, or two for you, if I may?
Cruise control - Is it genuine Mitsubishi or after market? How well does it work? Is it steering wheel or column mounted and who is the manufacturer.
I am in the process of trying to source on for our truck.
Thanks,
Wombat
FollowUp 2 of 2
AnswerID: 17307   Submitted: Thursday, Apr 10, 2003 at 14:54
i was told it was after market its mounted on the steering colum under the wipers it works great nice and simple an on/off switch and a set speed theres no resume or anything like that it cancels the speed once the brakes are applied and not with the accelerator. not sure which brand though there was no paper work on it and no brand name on it.
Reply 7 of 7
 Page Sponsors
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
Phone: 1800 21 21 21
