caravan tyres
Submitted: Tuesday, Feb 13, 2007 at 19:42
ThreadID: 42272 Views:15492 Replies:7 FollowUps:6
Can anyone give some advice regarding a good brand of tyres for a caravan to suit gravel roads. We have just travelled over 40.000 km on sealed roads without a problem with our Dunlop light truck tyres but we now hope to tow the caravan to Birdsville in the coming winter and are worried that the tyres will not stand up to the conditions. Can anyone help?
Reply By: Mudness - Tuesday, Feb 13, 2007 at 20:06
Hi GL, I have had a great run out of the Bridgestone R633's. Put as set of these on and you wont have any probs. Cheers
AnswerID: 221494
Follow Up By: GL - Tuesday, Feb 13, 2007 at 20:10
thanks for the advice. I will check them out. Cheers
FollowupID: 482242
Reply By: Member - Axle - Tuesday, Feb 13, 2007 at 20:32
As your dunlops are a light truck tyre, with the right pressures they may well be ok, what else is there apart from light truck tyres for a van ?. Just different brands, 40,000 ks and no probs is a good run, stay with them.
Cheers Axle.
AnswerID: 221502
Follow Up By: GL - Tuesday, Feb 13, 2007 at 20:43
Thank you Axle, you make perfect sense, my thinking was that all of the 40.000 km was on sealed roads and I thought that perhaps there was a tyre more appropriate for gravel roads. the answer may be to stay with light truck tyres and carry an extra spare.
Thanks again,
GL
FollowupID: 482249
Reply By: SA_Patrol - Tuesday, Feb 13, 2007 at 22:28
All depending on what tyre and weight of Caravan you have but running between 22 to 24 psi might be advisable on gravel roads
AnswerID: 221545
Reply By: Member - Charlie M (SA) - Tuesday, Feb 13, 2007 at 23:01
Gday GL
Ignore that pressure of 22 to 24 psi a mile to low for a caravan would cut sidewalls out in no time. How old are tyres on van, if about 5 years old REPLACE as they start to give trouble from about that time. Would use B/stone 633 myself. But goodyear, toyo, firestone cv 4000, kumho, hankook would all do the job. Would steer clear of cheap imported tyres as some do not wear all that well.
Charlie
AnswerID: 221558
Follow Up By: GL - Wednesday, Feb 14, 2007 at 08:31
Thanks Charlie,
The Caravan is a 2 year old 18'6" Regal twin axle and the weight is 2.2 ton fully loaded. The original tyres (still fitted) are Dunlop SP LT5. As mentioned above, they have travelled 40.000 km right around Australia on the bitumen without a single blow-out. The spare is still brand new. Having gone all the way around, we now are now preparing to go through the middle. The tyres still have a little life left but I do not wish to tackle gravel roads with them. The recommended tyre pressure by Regal is 50 PSI and I have kept it at that all along. I agree that 22 PSI sounds a bit low given the weight of the van. B/stone 633 may be the option is they are better than the Dunlop on the gravel.
GL
FollowupID: 482322
Follow Up By: Member - Charlie M (SA) - Wednesday, Feb 14, 2007 at 09:44
Gday GL
Re your question? personal pref is all the differance between the two to do the job.
Re preisure for your tyres at that weight is about for the following size 185R14C 45psi. 195R14C 40psi
Charlie
FollowupID: 482330
Follow Up By: Member - Charlie M (SA) - Wednesday, Feb 14, 2007 at 09:46
should be pressure
charlie
FollowupID: 482331
Reply By: traveller2 - Wednesday, Feb 14, 2007 at 08:23
Any of the LT steel radials will do the trick, put the tallest size on that you can and depending on the weight I'd be running around 36 + or - .
Remember these tyres can carry a lot of weight with up to 60 or 70 psi on a light truck or van.
I've run around 35 psi for years on a camper that weighs less than 600kg's loaded, never had a puncture and that has included over 200k kilometres of outback tracks and roads.
AnswerID: 221595
Follow Up By: T-Ribby - Wednesday, Feb 14, 2007 at 14:10
Thanks, that answers my question re pressures for my camper-trailer which has 215/60/R16's. (all up weight approx 550-600kgs) I run them at 34psi on the seal and 30 on dirt. Putting new Goodyear G26 LT cargo's on for the winter.
T-Rib
FollowupID: 482390
Reply By: SA_Patrol - Wednesday, Feb 14, 2007 at 18:09
I'm sorry GL I didn't know the 633 was such a small tyre, but I must say I do have a ski boat with 14" Lt tyres weighting 1.7 tons and I do run between 24 and 30 psi. on gravel. each to their own option.
AnswerID: 221717
Reply By: GL - Wednesday, Feb 14, 2007 at 20:23
thanks everyone, as usual the forum has provided some great advice. I guess the consensus is that any of the good Australian made brands of light truck tyres will do the job. I will carry an extra spare and lower tyre pressures slightly from the factory recommended 50 psi.
cheers to all,
GL
AnswerID: 221754
