lightforce xgt - GU
Submitted: Tuesday, Feb 13, 2007 at 23:00
ThreadID: 42284 Views:2362 Replies:5 FollowUps:3
Just confirming, does the XGT 240 fit onto a genuine GU bar? And what is the most cost effective way to improve the high beam? (aside from d. lights)
Reply By: Voxson - Wednesday, Feb 14, 2007 at 07:56
They fitted on my GU Steel Bar,, but i had to redrill a coupla new holes a little forward of the originals so the top of the lights would miss the top bar..
And those Crystal Vision replacement bulbs are pretty good made by Phillips...
AnswerID: 221591
Follow Up By: Member - Roachie (SA) - Wednesday, Feb 14, 2007 at 08:16
Same here.....as far as the XGTs goes anyway.
With the headlights, I went down the track of fitting HID kit from Xenonoz. Expensive but worth it IMHO
FollowupID: 482319
Follow Up By: Bonz (Vic) - Wednesday, Feb 14, 2007 at 17:49
yannow if you just turn the bracket bases around the XGT's miss the bar and no re drilling
FollowupID: 482434
Reply By: Gossy - Wednesday, Feb 14, 2007 at 17:26
two quesions:
1. The replacment globe is better than the original (I'm not complaining about the light output I have now!)
2. you can fit HID fitments to them! How much did it cost and who does it?
Thanks,
AnswerID: 221699
Follow Up By: Truckster. - Thursday, Feb 15, 2007 at 12:59
costs vary from $150 to 600
who does it ? You do it yourself, you buy the HID kits, and Bushy555 on Outerlimits has the instructions.
He also sells the kits, has some great 50w HID kits and knows EVERYTHING about converting XGT's and others to HID
FollowupID: 482629
Reply By: Bonz (Vic) - Wednesday, Feb 14, 2007 at 17:48
Mine fit great, I just turned the bases around on the brackets and viola NO REDRILLING, easy as 1 2 umm oh yes 3.
I fitted 100/130w H4 globes to the headlights made a heap of differnce, also wired hi and lo beam up thru seperate relays.
AnswerID: 221706
Reply By: Macca_GU - Wednesday, Feb 14, 2007 at 23:36
One option NOT to try when doing a headlight upgrade are the IPF Fatboy globes. IMHO they are no better than the Phillips 20% plus globes that I replaced them with. Phillips $40 pair. Fatboys $150 pair. You don't ALWAYS get what you pay for....lol
AnswerID: 221799
Reply By: Member - Miles P (VIC) - Thursday, Feb 15, 2007 at 12:10
Excellent, thanks for the help, time for a total light upgrade.
AnswerID: 221864
