Lift for 1998 2.8 GU Patrol
Submitted: Thursday, Feb 15, 2007 at 16:39
ChuckyGU
I am looking at buying a second hand set of 33" x 12.5 15BFG Muddies on 15x 8 Sunraysia's and have tried them on and fit ok just may look at rubbing when on full lock on the rear mudflap and was thinking I may have to do a lift to keep clear! I am looking for any advice from you guys as a newbie so be kind!
Reply By: rolande- Thursday, Feb 15, 2007 at 20:41
G'day ChuckyGU,
Check brake clearance, this is the main reason for moving to 16" rims.
If you do have some rubbing a 2" lift will sort that out as
Most common tyre size used on GU other than 265/70X16 is 265/75 X 16", (which corrects speedo error), or the larger 285/75 x16".
Remember that lifts and bigger
wheels will reduce fuel economy and may mean using a lower gear than normal as
well. The 2.8 is "adequate" for the weight of the GU, certainly no powerhouse
Rolande
221957
Reply By: Pezza (Bris) - Friday, Feb 16, 2007 at 02:27
Hi Chucky,
You just need a basic 2" lift, which in reality will most likely only lift your vehicle about 1 1/2 to 1 3/4 inches.
This "lift" consists of 4 springs and 4 shockies, you can forego the shockies till a later date if you wish, though you will not gain any extra wheel travel as the aftermarket shocks are a little longer when at full stretch.
I was quoted $700 for a full set of 4 X springs and 4 X shocks ( EFI brand ) for a GU. from Ace Tyres in Hemmant (
brisbane ).
Not sure on fitting costs, as I do
mine myself, it's not that hard.
With only a 2" lift you most likely won't need caster correction bushes, adj. panards or anything else the big companies try to sell you and 15 inch rims fit fine on a GU.
Not sure where you are, but if your in
brisbane let me know, I'll give you a hand to put them in if you do decide to buy some.
Avagoodn
Pezza
222016
Follow Up By: ChuckyGU - Friday, Feb 16, 2007 at 10:52
Thanks for the info and offer Pezza and if I was in Brissy not
Adelaide I would definately take you up on the generous offer! I think I will do the lfit kit I suppose I will now open a bucket of worms when I ask people what
Suspension system they would recommend!
Looking forward to many varied and different replies!!
Chucky...
482851
Reply By: ChuckyGU - Friday, Feb 16, 2007 at 11:17
Adelaide I would definately take you up on the generous offer! I think I will do the lift kit I suppose I will now open a bucket of worms when I ask people what
Chucky...
222069
Reply By: ChuckyGU - Friday, Feb 16, 2007 at 11:18
Chucky...
222070
