follow up Paj won't start
Submitted: Thursday, Feb 15, 2007 at 17:36
ThreadID: 42348 Views:2452 Replies:8 FollowUps:5
Greetings, The pajero still won't go, spark comming out of coil no spark comming out of the dizzy 3ltr petrol
replaced the module in the dizzy still nothing had leaking water on the passenger side could it have penertrated some vital electrics e.g. relay, computer etc. this driving me nuts. Thanks...........Hazza
Reply By: Oldsquizzy (Kununurra) - Thursday, Feb 15, 2007 at 18:34
Do the simple checks like fuel pressure and flow . check injector pulse.
AnswerID: 221930
Reply By: Kiwi Kia - Thursday, Feb 15, 2007 at 18:39
What model & year Pajero ?
AnswerID: 221931
Follow Up By: harry56 - Friday, Feb 16, 2007 at 06:33
She is 92 NH
FollowupID: 482806
Reply By: Peter 2 - Thursday, Feb 15, 2007 at 19:22
I probably has a crank angle sensor too which will stop it if disconnected or broken.
AnswerID: 221937
Reply By: Member - John W (VIC) - Thursday, Feb 15, 2007 at 20:15
Hazza
How did you determine there is spark coming out of the coil and not coming out
of the distributor.
AnswerID: 221951
Reply By: Eric Experience - Thursday, Feb 15, 2007 at 22:03
Harry
Where are you located? Eric.
AnswerID: 221979
Follow Up By: harry56 - Friday, Feb 16, 2007 at 06:39
Eric
Late yesterday I handed it over to the Rawsons the local mechanic in Officer Vic they are very good hopefully they will sort it quickly.
Harry
FollowupID: 482807
Follow Up By: Eric Experience - Friday, Feb 16, 2007 at 21:28
Harry
That is remarkable ,I was at Rawsons myself yesterday afternoon, If they can not fix it, let me know as we live in the same town. 59432267 Eric.
FollowupID: 482997
Follow Up By: harry56 - Saturday, Feb 17, 2007 at 08:40
Eric
As of the other day they still had not found the problem replaced the module in the dizzy but no luck now they back tracking the problem,I've got the burgandy coloured Paj excuse the spelling I'am just around the corner from Rawsons.
Harry
FollowupID: 483079
Reply By: Barnray - Friday, Feb 16, 2007 at 05:55
I would be checking for a cracked distributer cap or rotor button or your leads may have to high a resistance. Barnray
AnswerID: 222024
Follow Up By: techo2oz - Friday, Feb 16, 2007 at 22:13
Happened to me this one. Different car but same symptom. Went through water, car stopped. Changed coil, leads, rotor, plugs anded up a hairline crack in dizzy cap.
Spark goes in then dissappears.
FollowupID: 483010
Reply By: harry56 - Friday, Feb 16, 2007 at 06:40
To all thanks for the replies.
Hazza
AnswerID: 222027
Reply By: Rock Crawler - Friday, Feb 16, 2007 at 07:53
Very common problem , you did the module , now change your computer , left front kick panel , they alway blow hand in hand.
AnswerID: 222031
