AnswerID: 16979 Submitted: Sunday, Apr 06, 2003 at 16:48
Rob
replied:
This is for diesel!
On the Canning, we had 3 x Plastic Jerries = 60L + 4x20L emptied oil
drums. We emptied first the drums then the jerries into the vehicle
tanks at the start of each day. Then put the empties on the roof rack. One of the drums had a slight leak from the lid.The others worked well.
The vehicle was a 1HZ cruiser with sub-tank. Tip - make sure your containers are sitting on a flat level surface within the vehicle and are securely ratcheted down. Also check them daily for leaks.
After a 10 month trip - we only occasionally used the jerries (e.g. Gunbarrel, Canning, Simpson or to avoid high
fuel prices). The drums
worked well and could be picked up for free from servos and binned
at the end of a trip section - freeing up space.
I'm not sure of the legality of non-approved fuel containers - but they did the job & I would use the same idea for the next trip instead of buying jerries which only saw occasional use.
Rob (flameproof jacket on!)
Reply 9 of 12
