Solar - True or false
Submitted: Saturday, Feb 17, 2007 at 18:44
3F62
Tried "search" no joy..... I run a BP 80w panel (free standing) to 2 x 6 volt 220 a/h deepcycle batts without a regulator on the C/T & power a waeco CF50, 2 x 9watt fluros & a 330w inverter sometimes....... Batts monitored a few times through the day whilst in
camp via a multimeter....... Question I have heard that leaving the panel conected overnight can drain batteries back throught the solar panel if no diode is connected............your thoughts ?????
Chris
Reply By: Jimbo - Saturday, Feb 17, 2007 at 18:51
True.
My first regulator was a cheapie and I put the panel on after dark and hit the contacts on the battery with a multi meter. There was avoltage drop suggesting leakage back into the panel.
Using a solar panel without a regulator is dangerous. Panels put out between 17 and 19 volts. This will "
wellington boot" your batteries. A decent regulator will only set you back $100. Good investment.
ATB,
Jim.
222330
Reply By: FZJ 80 - Saturday, Feb 17, 2007 at 20:02
3F62,
I have also a BP 80W panel. I bought
mine from Derek (ABR) and a Morningstar Regulator. This Reg fits straight into the wiring box on the back of the panel. Stops draw and is set and forget. $95.00 from memory.
Enjoy
222338
Reply By: acdc - Saturday, Feb 17, 2007 at 20:42
It's true, but the extra power gained during the day without a diode exceeds what you would lose at night.
If you have a constant load on the system i would'nt worry about a reg, one panel will never overcharge, your fridge and lights use more than what your panel can produce.
222346
Reply By: V8 Troopie - Saturday, Feb 17, 2007 at 20:53
Very unlikely Chris. I was curious about this reverse blocking diode thing too so I connected a battery to my panel and turned the panel upside down indoors to make sure no light at all got to it. I then measured the reverse current, I should say that I tried measuring it. It was so small as to be ignored, IMO. I did remove the panel's diode for the test and no regulater was connected.
Different panels may give different results so why try it not out yourself?
For a permanent panel set up the diode may be useful but then not all diodes are created equal. The ones usually fitted to the panel drop at least 0.5V, Something I loathe to waste. There are Schottky diodes available which have a much lower (~0.2V) voltage drop. I fitted one of these to the panel that keep my boat batteries charged which is a permanent set up, the boat lives on its trailer when not on the
water.
Klaus
222350
