Rigrunner
Submitted: Sunday, Feb 18, 2007 at 18:10
Strahan
Anyone know of an Oz distributor for these? Seem to be the best thing for a fuse box that I can find. Otherwise it looks like a marine product might have to do.
www.westmountainradio.com/RIGrunner.htm
Reply By: Peter 2 - Sunday, Feb 18, 2007 at 18:22
Can't help with them but I've used those stainless/plastic fuseboxes from whitworths with great success, they use the old glass type fuses and have screw type connections to take an eye terminal.
222497
Reply By: Member - Gadgets (VIC) - Sunday, Feb 18, 2007 at 21:19
Strahan
these seem very good but what is the application? I have used a couple of these from Hella in my vehicle and they work fine.
hella online catalogue
no association with Hella
222553
Follow Up By: Member - Gadgets (VIC) - Sunday, Feb 18, 2007 at 21:20
should have said the "blade type" although there is a waterproof one as
483379
Reply By: Strahan - Tuesday, Feb 20, 2007 at 15:43
I am going to run several things through it. The main one is an HF amateur radio which can draw up to 25 amps. This is the biggy- box needs to be able to cope with that. Others are only engel, invertor, and a few bits and pieces. Had a look at Blue Sea? ones from the boat
places which might do the job. The rigrunner looked the goods because of the easy plug set up.
Will keep looking!!!
222925
Reply By: Member - Matt M (ACT) - Tuesday, Feb 20, 2007 at 15:52
Strahan,
Why run the HF through a separate fuse box? Most advice I gathered before installing
mine would suggest running the power direct from the battery noting that the radio has its own fuse.
Just interested.
Matt.
222927
Follow Up By: Strahan - Tuesday, Feb 20, 2007 at 21:22
Aha, you spotted that!
Well the radio I have has a funny connector. I was going to buy another so i can use it at home and in the car. The original power cable is $40.00 for 2 bits of wire. Bit expensive!!! I can get one from the states for $11.00 which does not have fuse holders in it. Hence running itthrough the fuse box. Does seem a roundabout way to do it, but sort of makes sense.
483847
