Wondered what the smell was.
Submitted: Monday, Feb 19, 2007 at 14:47
RovingOz (QLD)
Started to get a musty smell in the cabin recently so today I lifted the vinyl matting under the passenger side
well and found the insulation backing soaking wet and the wiring loom sitting in a nice pool of
water down the side!
I have scrapped all the soaked backing off the vinyl and dried out everything.
Both floor grommets are in place and okay. On further investigation I popped the small hard plastic round cover (about 60mm dia) from the hole in the passenger floor just as the floor slopes up at the front. It allows access to a chassis bolt. You can see into a small
well. Put your finger in and there is
water sitting there. It must seep into the passenger floor somehow.
Soaked it up but need to find out where it's coming from.
Anyone had this before?
'02 78 TD
Reply By: joc45 - Monday, Feb 19, 2007 at 14:55
In my experience, the most common source of
water getting in is via the windscreen seal. Can be very hard to locate, as the
water often runs a fair distance around the seal before trickling down into the foot
A leak problem I had in my Patrol only happened in downpours. Nissan tried to find it during warranty, but in the end reckoned that they might have to take out the dashboard, at my expense. I baulked. Eventually found it a year or so later when I changed the windscreen; there was a 1cm gap in the sealant.
Try using a high pressure hose around the windscreen seals, while someone watches for
water trickling under the dash.
Gerry
222681
Follow Up By: Member - Peter R (QLD) - Monday, Feb 19, 2007 at 15:04
From experience check that the sealant is inserted on the outside of screen , particularly at top.
If none there this can cause a leak.
Pedro
483521
Follow Up By: Scoey (QLD) - Monday, Feb 19, 2007 at 19:37
Also sprinkle some talcum powder around the inside before you go blasting the seals and that will show up even the smallest leak!
Scoey!
483569
Reply By: Member - DARRYL S (QLD) - Monday, Feb 19, 2007 at 15:13
Joc
Check your door drain plugs, could be blocked, letting
water to leakunder your
door linings.
Darryl
222682
Reply By: Dave198 - Monday, Feb 19, 2007 at 16:02
John, I think I would replace the plastic cover you saw with a rubber grommet.
Quite often the plastic types just don't seal properly.
222697
Reply By: Scoof - Monday, Feb 19, 2007 at 16:04
Have you been using the aircon . My brother in laws car leaked the condensate
water from aircon all over the left hand floor.Local mechanic cleared it with air.
May be the problem ??????????????
Cheers Scoof.
222698
Follow Up By: pepper2 - Monday, Feb 19, 2007 at 16:15
ive had the same with blocked air cond outlet hose ,hose blocked
water drains into passenger foot
well
483531
Reply By: Member - Boo Boo (NSW) - Monday, Feb 19, 2007 at 16:50
Had a similar problem very recently in my troopy.
Found it was a large gash in a grommet in the fire wall on the passenger side.
At first I was convinced it was the windscreen.
Try checking the two holes (There is a technical term) on the bottome part of the frame the rubber sits in. Sometimes these are blocked. The windscreen man checked
mine when the screen was replaced.
They are about equal distance from each side of the screen. You may be able to get to them by carefully lifting the rubber.
Regards Boo Boo
222712
Reply By: Mr Fawlty - Monday, Feb 19, 2007 at 19:27
Shades of my son "Dad my car stinks" Ok I'll have a look says I. Took me 3 nS to find the problem... A person or persons unknown had left a dead fish under the drivers
seat....Obviously not a popular lad...
222746
Follow Up By: Member - Brian (Gold Coast) - Monday, Feb 19, 2007 at 19:48
"A person or persons unknown had left a dead fish under the drivers
seat....Obviously not a popular lad... "
ROTFLMFAO!!!!!
483571
Reply By: RovingOz (QLD) - Monday, Feb 19, 2007 at 20:47
Thks all
Found it.
Some bloody sparky in the past has removed a loom gromet through the firewall so when it rains or I clean it runs down the loom straight into the
well. Mungrel.
Where's that tube of silicone...
222764
Follow Up By: Member - Pedro the One (QLD) - Tuesday, Feb 20, 2007 at 00:20
Hi, RovingOz ..............
Exactly the same problem on my Model 75 Troopy ......... some tit recently installed a dual battery set-up in the rear of the Troopy and ran the wiring [HD] through the same grommet and tore the bottom half .......... rain or washing did the same as yours. Local Smash Repairer found it straight away and plugged it with "some black faeces !" Worked like a charm .
And I'll not be doing my own wiring again ................ damnnnnnnnnn !!
483648
Reply By: Robnicko - Tuesday, Feb 20, 2007 at 10:27
RovingOz,
With 80 series cruisers they have a dry seal meaning the rubber mould is placed around the screen and then its popped into the windscreen frame, unlike some cars where sealant (hot glue) is used to hold the screen in place. From what i have been told it is to avoid cracking windscreens when the body flexes and to make replacement easier. When I had a new screen put in on my cruiser O'Briens told me that. They also said to always insist on a genuine Toyota Seal as opposed to the aftermarket ones which are prone to leaking. Toyota have the chrome strip all the way around, aftermarket ones do not..
Mind you down here in Vic i reckon we we could cut the roofs of our cars as rain is only a distant memory!
Rob
222869
