Patrol 4.2 Owners
Submitted: Tuesday, Feb 20, 2007 at 11:20
ThreadID: 42516 Views:2853 Replies:4 FollowUps:7
after a weekend of play, and lack of power shi__ing me off, i was in the engine pay of the GU with the degreaser and a scrubbing brush and came accross the source of my frustration.......my waste gate controller was STUCK! Stuck at about half way! I cleaned it up and lubed the area with the good old WD40, check for full operation, and test drove! OMG!! the 285/75's were sqeeling..... It must have been like this since i bought it 6 months ago, as it has never had this much power before. I ordered the 3" dump pipe and exhaust from BD exhaust last week, so i cant wait to install it and see the power grow.....
Reply By: Flash - Tuesday, Feb 20, 2007 at 11:50
Buy yourself a boost gauge! VDO sell a beauty.
You need this to know what it's doing- otherwise you can have problems with over OR under boost. I wouldn't have a car without a temp gauge, and I wouldn't have a turbo without a boost gauge.
AnswerID: 222884
Follow Up By: Wayne-o - Tuesday, Feb 20, 2007 at 12:43
Where and how does it fit on?
FollowupID: 483729
Follow Up By: tomjones83 - Tuesday, Feb 20, 2007 at 16:55
Seems to have gone offtrack on ya a bit there wayne-o. Autotechnica make a nice gauge too. generally you have to run power from your parker light circut so it lights up when it should and you will need to buy a t piece and cut into the vaccume line running to the wastegate. i dont have a diesel patrol so not sure exactly where the line is but you should be able to find it. if in bris i can assist ;-)
Tom
FollowupID: 483766
Follow Up By: Flash - Tuesday, Feb 20, 2007 at 16:55
Very simple fit.
You just need a T in the line from the manifold to the wastegate controller, or a simple outlet fitting screwed into the manifold.
It senses boost pressure in the manifold downstream of the turbo- and you therefore know exactly what the turbo is doing.
Not sure, but I suspect yours would be running between 8 to 12 psi boost, depending on the set up. (Mine runs 12 psi, which it reaches at about 2000 rpm. ) As soon as there is any problem with the wastegate or controller you'll know because boost will be abnormal.
Find your local VDO outlet- you need the gauge (0-15 psi) plus fitting kit- just a plastic tube with fittings. Don't get one for a petrol engine- they have vacuum AND boost.
Mine cost about $80 all up from memory, a few years ago.
God knows how many engines have blown up over the years because the boost has gone wrong due to a sticky wastegate or whatever, with the driver having no idea.
As I said, I wouldn't own a turbo without one.
FollowupID: 483768
Follow Up By: Member - Brian (Gold Coast) - Tuesday, Feb 20, 2007 at 20:05
Boost guage gets my thumbs up as well, and a Pyrometer!!!
FollowupID: 483818
Reply By: troopyman - Tuesday, Feb 20, 2007 at 12:59
How does it feel to own a volvo .
Site Link
AnswerID: 222890
Follow Up By: Wayne-o - Tuesday, Feb 20, 2007 at 13:16
same as it did to own a nissan, 3 toyotas, 2 clubsports and a ford. Very satisfied, when im not i buy a new one.....ha ha
FollowupID: 483733
Follow Up By: Pajman Pete (SA) - Tuesday, Feb 20, 2007 at 14:54
Oh great, does that mean all the nissans will now be driven like OVLOVs? Except Roachie's and Bilbo's of course who don't have a nissan diesel anymore.
Pete
FollowupID: 483750
Follow Up By: Member - Matt M (ACT) - Tuesday, Feb 20, 2007 at 15:17
I have a friend that has a GU 3.0 Diesel AND a BMW R1100. This explains why he has tried to run himself over several times.
Matt.
FollowupID: 483752
Reply By: whyallacookie - Tuesday, Feb 20, 2007 at 15:11
It won't make much difference at all to Nissan Owners. Nissan Diesel is not the same as Nissan automotive. This sin't like the Nissan/Renault alliance, they aren't sharing platforms or technology.... Now Nissan Truck owners that's different.
AnswerID: 222918
Reply By: Member - Duncs - Tuesday, Feb 20, 2007 at 17:16
Does it mean spare part prioces will fall?????
Nah didn't thnk so either.
Duncs
AnswerID: 222940
