suzie coil
Submitted: Wednesday, Feb 21, 2007 at 09:42
Member - Mal B
just finished my fridge tilt any ideas on a suzie type coil for the fridge wire thanks mal
Reply By: Member - Doug T (W.A) - Wednesday, Feb 21, 2007 at 10:20
Mal
as I was typing your other message an Idea came to mind, So your looking to run just an Electrical wire to the fridge , oh Suzie Coiled of course , Now I'm not sure if you could buy one ready made , So as I mentioned Air lines in the message, what I would do is pop off down to the supercheap store and get a coiled airline, the little one made just for blowing dust , Truckies have them under the
seat , so what you do is cut off the required length and feed the 12v wiring through it , there you have what you need , a Suzie Coil for your fridge, .......Oh I have already put a Patent on that idea ....lol
223103
Reply By: Member - MUZBRY (VIC) - Wednesday, Feb 21, 2007 at 12:24
Just go down to your local truck
shop and buy an electric Suzie coil . All will be
well.......
223133
Reply By: whyallacookie - Wednesday, Feb 21, 2007 at 14:19
OK, WHat's a suzie coil? (I went out with a
young lady called suzie once.... anyway)
I'm guessing it is the coil piece that you see behind the cab on a prime mover for the air/power lines going to the trailers?
223166
Reply By: Red One - Wednesday, Feb 21, 2007 at 18:21
Commonly know as a pig tail.
223204
Reply By: Member - Mal B - Wednesday, Feb 21, 2007 at 20:39
thanks , looked at all of the above problum if you cut the engil fridge wire to slide through a hose [
mine is hard wired] the ends are the molded type. i surpose you could splice the cable near the plug, tried to buy after market ends no luck thanks mal
223239
Reply By: geocacher (djcache) - Saturday, Feb 24, 2007 at 00:21
Hey Mal,
Any chance of some pics of the fridge tilt?
You can run the power cable down the coiled air line from Enzed. While you are about it get rid of the cigarette lighter plug and put a decent plug on it.
I haven't bothered with
mine, just cable tied it to the cage with enough of a loop for the movement.
You used to be able to get coiled mains leads which would also do the job but they weren't cheap.
223672
