battery woes
Submitted: Wednesday, Feb 21, 2007 at 21:47
Mickpaj
just want to know if anybody can tell me how long a deep cycle battery lasts and if there is any maintenance that should be carried out on them. The battery I have is less then 12 months old - exide brand maintenance free. The battery is now had it and I was told that it is my fault due to lack of maintenance. Please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Reply By: Eric Experience - Wednesday, Feb 21, 2007 at 22:48
Mickpaj.
Your battery is probably OK, very few people understand battery testing. If you get a charger on it for a few hours and then measure the voltage, with the charger off, you may save it. When a battery has been flat for a long time the plates get a white coating on them, this takes awhile to dissolve as you charge it, so you may have to charge it for many more hours. Eric
223272
Reply By: Topcat (WA) - Wednesday, Feb 21, 2007 at 23:04
I find it strange that you have a stuffed deep cycle battery that is less then 12 months old. Even if you fully discharged it every time you used it you should get at least 300 cycles out of it before it will loose capacity provided you have fully recharged it every cycle.. The proper way to charge a deep cycle battery is SLOWLY over a long period at low amperage (less than 10amps . If fully discharged this can take 3 or more days depending on the capacity. A deep cycle battery is not designed to take fast charges at high amps like normal start batteries which are used to delivery high current for short period whereas a deep cycle battery is designed to delivery low current over long period.
From experience I have found to get the best performance & long life out of a deep cycle battery is to never discharge it more than 50% (ideal is not below 75%). On an average I can get from six to eight years out of a deep cycle battery using this method. I have spoken on this topic many times on this
forum over the years & I have the batteries to back it up. Cheers.
223281
Follow Up By: Sand Man (SA) - Thursday, Feb 22, 2007 at 02:22
"I find it strange that you have a stuffed deep cycle battery that is less then 12 months old. Even if you fully discharged it every time you used it you should get at least 300 cycles out of it before it will loose capacity provided you have fully recharged it every cycle."
I disagree Topcat,
I buggered an Exide Orbital that was just over 6 months old.
It has nothing to do with the number of cycles you should get.
Flatten any deep cycle battery a few times and it will become sulfated, eventually resulting in the inability to recharge it at all.
In my case the fridge tried to keep running when the battery had dropped to <10.4 volts. (flat) Do this a few times and you can kiss the battery goodbye.
I now protect the battery with a low voltage cutout unit.
484166
Reply By: disco1942 - Wednesday, Feb 21, 2007 at 23:38
Mickpaj - More info please. Have you left it for any length of maintenance charge? Have you left it flat for more than 12 hours? This will sulphate it up on you.
Have you used a cheap chain store (Super Cheap etc) charger on it? These can over charge the battery and boil the
water out of it. If you use one of those chargers you should halt the charging before the battery becomes fully charged
To charge and maintain a deep cycle battery you really need a good three stage charger and/or a large solar panel with a good controller like MorningStar.
223289
Reply By: Moose - Thursday, Feb 22, 2007 at 14:25
It's a maintenance free battery you said, so apart from charging it after use there isn't much you can do. Agree with the slow charge comments above. How do you know it's stuffed? Get a second opinion - they may just be trying to sell you a new one unnecessarily.
223372
