Around Oz from Perth - Which way in August ?
Submitted: Wednesday, Feb 21, 2007 at 21:56
ThreadID: 42571 Views:2873 Replies:3 FollowUps:8
Gday,
Heading off on the big trip for 6-12 months (or maybe more) leaving from Perth at the start of August circumnavigating Oz. Would love to go north (clockwise) first however as it is nearing the end of the dry season, would it be better to go east first (anticlockwise) ?
We are worried if we head up to the Kimberleys first there may not be to much water in the gorges and waterfalls. The dillema if we go east first is that by the time we hit Cairns, Cape York will be too wet and we will have to sit it out till maybe May/June.
Any recommendations greatly appreciated?
Birdy
Reply By: Member - George (WA) - Wednesday, Feb 21, 2007 at 22:05
Lucky bugger, over the top via WA first, to beat the wet. Cheers
AnswerID: 223261
Follow Up By: Birdy - Wednesday, Feb 21, 2007 at 22:58
Yep cant wait to finish work and head off ! Only prob going North is probably no flowing water in gorges and waterfalls. Hopefully its a late wet season if we do go North first !!
FollowupID: 484144
Reply By: Member - Norm C (QLD) - Wednesday, Feb 21, 2007 at 22:17
North is the go. Miss the southern Winter and get across the top in the dry season. If it's early August you are leaving, you have at least 3 or 4 months, though it will start to warm up a bit from September. Also the chance of some storms in November, but not the real wet.
If you go across to the East, you wouldn't want to be hitting the far North until late April at the earliest, possibly later depending on the wet season. So it would need to be a 12 month trip. Going North first gives you more flexibility.
Your points are valid though. The North is best (I think) just after a wet, rather than just before. But the only way you can go East is if you are prepared to give the trip a full 12 months. If you decide to cut the trip short, it will be the North that you will miss a lot of as you really can't do it too early
AnswerID: 223267
Follow Up By: Birdy - Wednesday, Feb 21, 2007 at 23:01
Cheers Norm. Was thinking along the same lines as you mentioned however would really like to see some water, espescially to cool off ! we have a baby who will be 1 when we leave so the heat factor may also be a problem however im sure we can sort that one out .
Thanks for your detailed response. Cant wait to hit the dirt roads ......
Birdy
FollowupID: 484146
Follow Up By: Andrew from Vivid Adventures - Thursday, Feb 22, 2007 at 08:06
There is still plenty of water most places up North all through the dry - maybe not wet season torrents, but Kimberley, Kakadu, Litchfield all have water pretty much all year around.
FollowupID: 484183
Reply By: Willem - Wednesday, Feb 21, 2007 at 22:54
G'day
Anticlockwise....as you will have the tradewinds blowing you along.
You will have to plan your journey a bit better so as to get to your destination places at the right time, weatherwise.
You will only see about a 10th and will have to do the trek many more times in all directions to cover and see many of the marvellous places.
AnswerID: 223275
Follow Up By: Birdy - Wednesday, Feb 21, 2007 at 23:04
Willem,
May end up going that way if we can take a year off and takeing around 5 months to do the east coast and hang up Far North Queensland till we can head to Cape York. Then we can carry on to the Kimberley, hopefully by June/July
FollowupID: 484147
Follow Up By: Troo Bloo - Wednesday, Feb 21, 2007 at 23:14
Birdy,
June/July best time to do the Kimberly, Gibb River Road, NT etc, i am going north from Perth but in June i think if i was to be leaving in August i would go east. All depends on time limit and what you want to see, if you get around GRR in March 08 it may not be open.
Good luck, see ya out there.
Troo Bloo
FollowupID: 484150
Follow Up By: Richard Kovac - Wednesday, Feb 21, 2007 at 23:30
Anticlockwise is also 9km shorter :-)
FollowupID: 484157
Follow Up By: Member - Duncs - Thursday, Feb 22, 2007 at 08:01
Now Richard,
I have two points of contention with you!!!
First, you have stolen my thunder, I always like to throw in the distance saved on this type of discussion.
Second, What I have been told from a number of sources is that it is actually 77km shorter. This saves you a full hour on the trip and is well worth considering. Who would really about 9km in a 30,000+km trip. Really! :-)))
Duncs
FollowupID: 484181
Follow Up By: Richard Kovac - Thursday, Feb 22, 2007 at 20:48
Duncs
I didn't realy know I made the 9km up..lol
FollowupID: 484295
