what type inverter?
Submitted: Thursday, Feb 22, 2007 at 11:16
Member - Tony J (NSW)
Hi All,
I have just bought a new HP laptop (our first) for the photos and OziExplorer when travelling.
Do I need a pure sine wave inverter or would a 'modified' sine wave type be Ok?
I'm thinking a 150 watt model would be sufficient.
When plugged into 240v at home the power pack charges the battery. Am I right in thinking the laptop runs off the battery as it is being charged?
I'm not considering a 12v adapter as the wife would also like to take her epilator! Hey, life is pretty good - a 2 month trip, a
camp fire, a cold beer and the wife with smooth legs and hairless arm pits - can't get much better!!!
Reply By: milzi - Thursday, Feb 22, 2007 at 11:33
Hi Tony,
Not so sure about the Pure / Modified
sign wave info however I can tell you that yes a 150w inverter would be plenty to drive your laptop, as far as charging etc while connected to 240v the battery chargers yes but the laptop itself is running off the 240v source, unplug the 240 and the battery will kick in.
Usually there are icons in the bottom right hand corner of your desktop
(among others) that shows you where your power is coming from... Battery or plug type icons! I could be wrong but I'm sure I have seen then on the HP's.
223357
Follow Up By: milzi - Thursday, Feb 22, 2007 at 11:34
And as for the second part of your post... no arguments here!
484204
Follow Up By: Scoof - Thursday, Feb 22, 2007 at 12:09
Just so every thing matches get a braziian inverter as
well.LOL Ha Ha
Scoof
484215
Reply By: Notso - Thursday, Feb 22, 2007 at 11:53
Mate I'd check your puters power supply as my toshiba uses about 1.8 amps at 240 volts so about 400 watts max.
nothing worse than not enough power for puter and having a bit extra is better than not enough. Goes for a lot of things in life doesn't it??
223359
Follow Up By: Member - John and Val W (ACT) - Thursday, Feb 22, 2007 at 14:23
Notso, My laptop power supply (Acer) claims 240V at 1.5A (that's 360W) input and puts out 19V at 3.5A (that's about 65W!). That's 300 watts gone missing and since it doesn't get hot there's obviously an error on the label. The fact is that my laptop consumes about 50 watts when running and/or charging. A small inverter (say 100W to be on the safe side) should run any laptop. Personally, I prefer to use a 12V power supply to run and recharge the laptop; no high voltage in the vehicle, and improved efficiency. Of course the inverter may have other, higher, uses which will probably be what dictates its power rating.
| J and V
- Albert Einstein
484239
Follow Up By: Mike Harding - Thursday, Feb 22, 2007 at 14:28
The 1.5 amps is the absolute maximum the power supply will ever draw - it probably takes into account the current surge which occurs for a fraction of a second when the power supply is connected to the mains. At all other times the supply will be around 85%+ efficient.
The 19V at 3.5A is what your laptop will use under worst case conditions, ie. 67 watts.
Mike Harding
484240
Follow Up By: Kiwi Kia - Thursday, Feb 22, 2007 at 15:40
My ASUS will not operate on a 300 watt converter but my ACER does work ok.
484250
Follow Up By: Mike Harding - Thursday, Feb 22, 2007 at 15:50
Fair enough Kiwi - I have no real answer for you but I find it hard to accept the laptop is drawing 350W+ (I guess the inverter will sustain short term surges?) even during the time it's charging the caps. in it's switched mode supply. Perhaps it's some sort of power supply protection in the ASUS which does not like something about your inverter waveform?
I use a Jaycar DC to DC converter which has a 120W max rating and that has operated perfectly with four different notebooks.
Mike Harding
484251
Follow Up By: Kiwi Kia - Thursday, Feb 22, 2007 at 17:51
Hi Mike,
The converter works fine with the ACER.
With the ASUS, every time the HD was being accessed the converter starts to protest and gives up if the disc access lasts more then a few seconds. I now use the ASUS on the desk and the ACER for mobile use.
484265
Reply By: Member - Jason S (SA) - Thursday, Feb 22, 2007 at 12:15
I have just been through this but I have gone the 12v path.
The father-in-law has gone the inverter path. Here is what he found.
No you don't need a pure sine for a laptop.
NEVER buy an inverter too small. It is the worst thing.
Whilst advocating the wife having smooth legs and armpits, will you are she use anything else 240v? Always the temptation. The only complaint that Jaycar get about their
inverters is that it will not power something because the customer bought one too small.
For about $300 you can get yourself a pretty hefty inverter with 2 to 3 times that power ( and more importantly 2 to 3 times the spike load ) with about 90% efficiency.
223362
Reply By: Member -Signman - Thursday, Feb 22, 2007 at 12:29
We've been using the 300W model from Jaycar for a few years with an old Toshiba lappy (may be more power hungry than the newer jobs).
Also handy for recharging batterys for the camera, handheld UHF & the vibrator..
223364
Follow Up By: Mike Harding - Thursday, Feb 22, 2007 at 14:29
I thought that was what you said...! :)
484241
Reply By: PhilZD30Patrol - Thursday, Feb 22, 2007 at 13:46
I am in a similar position and haven't got around to checking the inverter requirements. However I think they usually state if a pure sine wave inverter is required.
I support the other responses about using an inverter with insufficient wattage capacity, like towing a caravan with a 3 cylinder Daihatsu Charade, you might get started but it will fail. No need to go over the top either, about 10 - 15 % higher wattage should do.
Inverters get hot and heat decreases their efficiency so find a cool
well ventilated place to run your inverter.
Watts are calculated by multiplying the volts by the amps. My notebook computer specifications are that the DC input rating is 4.74 amps x 19 volts = 90.1 watts. So in theory an inverter with 100 watts output capacity should be sufficient but I will need to test it to be certain.
Remember to use quality cables, at least 4 mill copper and quality 12 volt fittings. Make the cable length as short as possible but still practical. 12 Volt DC can be unreliable if connections are dirty or loose. The negative return wire connections are just as important as the active.
Hope this helps
223369
Reply By: Rosco - Qld - Thursday, Feb 22, 2007 at 13:49
Tony
Contrary to the good advice above, I was strongly advised against using a modified sine wave inverter for anything you value. Apparently the battery chargers nowadays are electronic rather than simply an old style transformer and you run the risk of damaging your gear.
It's your call/your gear, but I'd
fork out the extra for the peace of mind.
223370
Reply By: Derek from Affordable Batteries & Radiators - Thursday, Feb 22, 2007 at 14:02
Hi Tony
As already mentioned by others you need more than 150W. Most laptops will surge out to around 350 to 400 watts on start up.
Best to have one that can more then do the job.
We have tested the Projecta 600W units on a number of laptops and cordless drills. This is the only modified wave unit we recommend.
Derek.
223371
Follow Up By: Member - Robert A (QLD) - Thursday, Feb 22, 2007 at 15:04
Hi Derek
Great information on your advertising page.
Hi Tony.
After reading that, Just to charge a lap top I would buy a DC/DC inverter and get the missus a good razor or you will always have a
camp fire to heat wax.
Rob
484247
Reply By: Grinner - Thursday, Feb 22, 2007 at 15:56
Regarding the Pure Sine Wave / Modifidied Sine Wave debate for running computers and laptops.
I stand to be correctted but I believe that 99.9% of laptop and computer power supplies are switch mode power supplies.
The first action a switch mode power supply does to the incoming 240v AC is rectify and filter it to DC. This is why I don't understand people saying not to use a MSW inverter.
I would like to hear to counter argument to this.
Grinner
223383
Follow Up By: handy - Thursday, Feb 22, 2007 at 18:33
grinner do you live in
melbourne. cheers
484269
Follow Up By: Mike Harding - Thursday, Feb 22, 2007 at 18:36
Agreed.
But... having said that... there have been one or two people who have reported issues with notebook power supplies...?
And I have had problems with two makes of fluorescent lamp which have burned up from a MSW inverter (GE ones worked OK) so, even though I design this sort of stuff, I am prepared to accept there are issues in some cases - but I don't understand why?
Mike Harding
484271
Follow Up By: Grinner - Thursday, Feb 22, 2007 at 20:35
handy, no I live west of
Melbourne.
Mike, I'm not doubting that people have had trouble, and I'm not about to plug in anything really expensive to my cheap MSW inverter, just makes me wonder why there are problems, when in theory a MSW inverter should present no problems to a Switch Mode PSU.
Grinner
484293
Follow Up By: festy - Sunday, Feb 25, 2007 at 09:49
You're right that *in theory* there should be no problem using a MSW inverter on a switctmode PSU, as the first step in a SMPS is to rectify to DC, so the shape of the waveform should have no impact - most SMPSs will actually run off a suitably high DC supply.
The problem some people have had with running laptops off a modified square wave inverter is that some (usually small, cheap) units will damage the laptop's battery over time. This happens because the modified square waveform 'collapses' under load, and the inverter sends very short, very high voltage spikes, probably due to trying to maintain the waveform. They don't seem to have any effect on the laptop (although I had one that made the CFL screen backlight pulse) they can have an impact on the battery cells over time, and drastically shorten the life of your laptop battery.
Having said that, a lot (most?) MSW
inverters will run and charge a laptop fine.
If you have access to an oscilloscope, you can quickly see if your MSW inverter is prone to the waveform collapse/spikes.
484689
Reply By: Richard & Leonie - Thursday, Feb 22, 2007 at 19:06
We had a 1000w inverter which was NOT supplied by ABR which lasted 2 secs. It came with our off road camper and was replaced by the camper people. This was a pain in
the neck as we were off the beaten track. By the time we did get to a town we were really missing it as we had planned for it. It cost $35 to send it back which is dead money and being on the road for three months it took a bit to organise where to collect the replacement. I am going to replace the replacement because I cannot be sure that it will last. The camper trailer company now tell me they have had numerous failures with
inverters supplied by this particular company, so much so they even considered legal action to recover losses. Mind you they never offered to refund the $35 to us but I can sympathize with them if they had a lot of failures. If you want to knw the name of the company email me.
I agree with the suggestions to go bigger because you can be sure the misses will want to plug the old hair dryer into it.
Richard
Richard
223410
Reply By: Leroy - Thursday, Feb 22, 2007 at 22:41
Why don't you look at the Targus or Kerio 12v laptop adapters? They plug into your cigi lighter skt. I personally have used a Targus for years on multiple IBM stinkpads and never had a problem. The issue with using an inverter is they are less ineffiecient and will suck more juice than a 12v adapter.
Leroy
223449
Follow Up By: Member - Jason S (SA) - Thursday, Feb 22, 2007 at 23:28
Yeah ,
This is the way I went. My Laptop pulls 19v @ 3.2a. The Kerio keeps up with it fine.
Inverters are getting better but I still wanted to maintain 12v in my Pajero.
484322
Reply By: Sand Man (SA) - Friday, Feb 23, 2007 at 00:23
Tony,
Go with the modified sinewave inverter to start with as they are significantly cheaper. I would suggest a 300 watt unit to give that bit more flexibility without compromising too much on size or cost. (e.g. charging camera batteries)
If you bought it from a reputable dealer and found when you got home, it won't run the Laptop, I'm sure you could return it an upgrade to a pure sinewave unit.
Just keep in mind, if you go any bigger than a 300 watt unit, you will probably need to upgrade the 12 volt socket to run it. 300W or less, you can plug into a standard ciggy socket.
Oh, and that bit about hairless armpits from the epilator, brings tears to my eyes!
223463
Reply By: Pajman Pete (SA) - Friday, Feb 23, 2007 at 08:25
I have a Projecta 12V laptop power supply that was great until work upgraded my laptop to a DELL - No one makes plugs to fit the Dell.
I ended up with one of those green coke can sized 150W units from Jaycar - it works fine.
Pete
223484
Reply By: Member - Tony J (NSW) - Friday, Feb 23, 2007 at 11:09
Thanks all who replied to my question.
So many differing opions, I'm still confused. I guess I'll contacted HP and see what they say.
The car is a bit tight on space, and the budget is tight also. I still have more gear to purchase for a 2 month trip so I don't want to over-spend on the inverter for extra I don't need. No other 240v gear (except epilator - no hair dryers allowed!).
Thanks again
Tony J
223510
Follow Up By: Gronk - Friday, Feb 23, 2007 at 12:06
He he, problem solved if you get rid of the epilator !!!!!!! Just use a razor, even better,YOU use the razor for her !!!!!!! I'm sure you'll get the hang of it .....
484379
Reply By: Dave & Shelley (NT) - Saturday, Feb 24, 2007 at 00:03
Hi Tony,
My two bob is buy big, you wont need to upgrade later. I was going to buy a 300W inverter last year and they had run out. I ended up buying a 600W for a small amount more due to a sale. We used it heaps last year to charge our ASUS laptop, Digi Camera, Mobile phones when used and a lantern. Usually only two at a time, but it was a god sent when we needed it.
Overall they are cheaper and smaller these days than most people think.
Happy charging
223668
