Oodnadatta to Marla Road
Submitted: Thursday, Feb 22, 2007 at 15:13
ThreadID: 42591 Views:3887 Replies:4 FollowUps:14
Wondering about taking a Mercedes Sprinter LWD van from Oodnadatta to Marla in July. The van has standard road tyres, is 7 meters long, 4 M wheel base, 1.5 M overhang with around 200 mm clearance. Clearance is less in some points are more in others. While road conditions can vary would appreciate your advice on whether tyres are suitable and issues with sand, creek crossings, etc. Have travelled Bourke & Wills Roadhouse to Lawn Hill with no problems. Keith
Reply By: Richard & Leonie - Thursday, Feb 22, 2007 at 19:23
I would say the tyres will not last the distence. The rocks on the road are pretty fierce.
Richard
AnswerID: 223413
Reply By: David from David and Justine Olsen's 4WD Tag-Along - Thursday, Feb 22, 2007 at 19:36
Drop the tyre pressures to a value that will give you 250mm long footprint front to back of the tyre. If this is 20% less than your highway pressure, then travel at at a speed that is 20% lower than highway speed at the very most, and all will be fine. Take it easy, take it slow, take 2 spares of each size (if different size front and back). Sand is not a problem, bulldust and rosks are, but with a low travel speed and care you can travel it in your van.
AnswerID: 223415
Follow Up By: T-Ribby - Friday, Feb 23, 2007 at 10:16
Is the 250mm footprint generally applicable to most tracks in the area, eg Birdsville
or just specific to the subject vehicle?
T.R.
FollowupID: 484369
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Friday, Feb 23, 2007 at 10:29
Generally applicable to those stoney roads, but it is imperative you slow down, as the vehicle will not handle as well wiht partially deflated tyres. So slow and steady wins in the outback.
FollowupID: 484370
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Friday, Feb 23, 2007 at 14:15
Give it a test in the driveway if you like. Drop one front tyre to give 250mm footprint and see what pressure it needs. Message me back if you like with starting pressure and pressure at 250mm. Oh be sure to pump it up again :-)
David
FollowupID: 484401
Follow Up By: T-Ribby - Friday, Feb 23, 2007 at 17:15
I've just done the exercise out in the garage on a level floor, front tyre, size
235/70R16
Starting pressure = 36psi
Footprint = 115mm
(loud hissing noise follows)
Finish pressure = 10psi
Footprint = 250mm
(and remembered to pump it back up again)
T.R.
FollowupID: 484425
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Friday, Feb 23, 2007 at 17:30
OK thats kinda what I expected. After posting I suspected they must be very solid tyres and not much weight up front, thats why I asked you to do the excercise. 10psi is too low for that sort of work. Go for 28 psi max and about 26 psi minimum. Reduce your speed 20%.
David
FollowupID: 484434
Follow Up By: T-Ribby - Friday, Feb 23, 2007 at 20:52
I concur with that David, I have 28psi offroad marked in my notebook of base settings for my tyres which are: 36psi tarseal, 28psi dirt, 20psi sand.
The tyres on the front are Simex 300i A/T Centipedes, hard rubber, and the whole vehicle unloaded only weighs around the 1600kg mark.
Thanks for the advice.
T.R.
FollowupID: 484470
Follow Up By: Solly - Friday, Feb 23, 2007 at 21:35
Hi David (4WD Tag Along), Thanks for the flow of information. I am running Bridgestone R623 225/70R15 (as original). Running 40 psi front & 55 psi back as recommended by Bridgestone. The tyres are 5 ply with 2 ply on side walls.
My concern is the vulnerability of the side walls. Appreciate your comment on this. Thanks, Keith
FollowupID: 484482
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Friday, Feb 23, 2007 at 21:43
Solly
Sidewall punctures are a red herring and as rare as hen's teeth in this sort of terrain. Almost 99% of punctures in this terrain are due to tread punctures ie stones penetrating the tread ara of the tyre due to tyre inflexibility and high speed.
If you lower the pressure, the tyre will flex around the sharp rocks. Lowering the speed by 20% decreases the risk of puncture by at least 40%. Sidewalls flex just like the tread only better, so lower pressure offers sidewall protection as well unless you maintain high speed in which cae you will run out of sidewall flex and puncture the tyre.
So lower pressure and lower speed, and keep weight down...it really is that simple.
FollowupID: 484485
Follow Up By: Solly - Friday, Feb 23, 2007 at 21:50
Thanks David, I will have a play with pressures here and give it a go. Keith
FollowupID: 484489
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Friday, Feb 23, 2007 at 21:55
Solly it may be worth measuring the footprint length at 26 psi on the frot and matching that length on the rear and seeing what pressure it gives you. My bet is it will be less than 30psi but more than 26 psi. If so then run with that pressure on the rear. This matching of footprint length is a good way to compensate for different loads front and rear. Feel free to message me if the pressures are outside my guestimate.
FollowupID: 484491
Follow Up By: T-Ribby - Saturday, Feb 24, 2007 at 10:36
Just out of curiosity I went out and compared the front and back prints.
Both tyres have 36psi. The rear print is less than the front ie 115 and 111.
So unloaded, there is a bit more weight over the front axle.
I won't change the pressures just yet, as it will be interesting to remeasure the print when there's a load in over the rear axle. I think it's a great idea to adjust the pressures to suit the load and must help even up the wear on the tread.
T.R.
FollowupID: 484561
Follow Up By: Solly - Saturday, Feb 24, 2007 at 12:04
Hi David (4WD Tag Along), I did a measure and test of the footprint this morning, and it was interesting. I know my highway pressures are good as the Sprinter van handles very well on the highway and minor roads. I have also had each axle over a weigh bridge at my mates place, and then got pressure recommendations from Bridgestone. These giber stone roads are a new venture for me.
------Anyway current normal conditions are as follows:
Front: Pressure 45psi, Footprint 190mm, Side wall bulge 25 mm.
Back: Pressure 55psi, Footprint 190mm, Side wall bulge 25 mm.
-----Tyre Pressure then dropped to get a 250mm footprint
Front: Pressure 26psi, Footprint 250mm, Side wall bulge 30 mm.
Front: Pressure 35psi, Footprint 250mm, Side wall bulge 30 mm.
Both front and back had a drop of 20 psi to achieve the 250 mm. This would give me a 31% increase in tyre bearing area, which must help. My only remaining concern is the bulging sidewalls as these are road tyres (2 ply walls) as compared to some off-road where the walls are virtually straight. But despite that, what you are saying makes sense, so happy to run with it. By the way do you take conventual (other than 4WD) vehicles on Tag Alongs??????
Many thanks for your help. Keith
FollowupID: 484568
Follow Up By: David from David and Justine Olsen's 4WD Tag-Along - Saturday, Feb 24, 2007 at 13:30
Solly
Ahhh that sounds a lot better. Run with those pressures. Sidewalls will be fine if you keep the speed down. All 4wd passenger tyres are 2 ply sidewall. Only the LT versions have more plys. It would be a good idea to fit Light Truck (LT) tyres if you plan to do a lot more of this kind of travel.
We are currently working on a couple of ideas for caravan/motorhome tag-alongs. Brisbane to Darwin is one we have in mind, the Savanah Way and shorter trips are also on the cards. You will find my contact details on this site. If you are interested in receiving our newsletter, we can keep you up to date with our plans.
David
FollowupID: 484584
Follow Up By: Solly - Saturday, Feb 24, 2007 at 13:57
Thanks David. That was most helpful. Keith
FollowupID: 484589
Reply By: RustyHelen - Thursday, Feb 22, 2007 at 20:56
If in doubt on the track to Marla, we did Oodnadatta to Cadney through the Painted Desert last July and road was fine. We camped at Arkaringa Station and there was a Mitsu van with road trailer and they had had no issues. Track is shown as a "lesser" road than to Marla on the maps and yes there were small rocks, stones and, if you went off the edge, larger rocks but travel carefully and you should be fine.
Rusty
AnswerID: 223427
Reply By: MEMBER - Darian (SA) - Thursday, Feb 22, 2007 at 21:37
Agree with David above - 2 spares, lower the pressures and drive very conservatively. You would be wise to phone the Pink Roadhouse at Oodna. (Adam or Lynnie) just prior to the trip - they welcome enquiries about travel in their region - check out their website.
AnswerID: 223436
