Waeco fridge not working
Submitted: Tuesday, Feb 27, 2007 at 02:12
Davidl63
My 1 year old Waeco Fridge is stuck on FREEZE, works ok on that setting , but cant turn the temp. down. Played with the buttons, don,t seem to want to move. What is wrong??? Do I need another temp control unit....?? If so I am having trouble finding a service place to fix it (assuming it is under warranty). Anyone got any contacts
Reply By: Peter McG (Member, Melbourne) - Tuesday, Feb 27, 2007 at 02:52
First check if you have the emergency switch set to on - this makes it run non stop. If there is still a problem then call Waeco on (07) 5507 6000 and ask them for the name of your nearest service depot.
224235
Reply By: Brew69(SA) - Tuesday, Feb 27, 2007 at 06:21
Your 1 year old fridge has a five year warranty. Waeco has lots of repair centres. As said above give them a ring.
224236
Reply By: Robnicko - Tuesday, Feb 27, 2007 at 09:07
definetly sounds like the red emergency switch is on.
224270
Follow Up By: Wizard1 - Tuesday, Feb 27, 2007 at 13:49
I agree, the same thing was happening with our fridge. I now have gaffer tape over the switch the avoid the likelyhood of switching on by mistake.
485195
Reply By: Member - Col G (WA) - Tuesday, Feb 27, 2007 at 10:37
Sounds like the thermostat is faulty if the switch is not on.
224290
Reply By: Howard T - Tuesday, Feb 27, 2007 at 13:49
Hi Dave
If its a CF50, on
mine it was a new control unit. Buttons would not move.
HowardT
224323
