moving map - it moves
Submitted: Tuesday, Feb 27, 2007 at 10:08
ThreadID: 42754 Views:2717 Replies:7 FollowUps:2
Finally got the moving map thingo working with the natmap 250k. Thanks to advice from people on here. it took me a while to figure out exactly how it worked as i played with that much stuff. There is a setting in the sytems menu for the etrexwhich has to be set to nmea out. However it has to be set back to garmin to download waypoints, tracks
Reply By: Member - Brian (WA) - Tuesday, Feb 27, 2007 at 10:20
Well done Davoe
AnswerID: 224286
Reply By: Member - Andrew (QLD) - Tuesday, Feb 27, 2007 at 10:28
Just don't touch it now that it is working :-)
AnswerID: 224287
Reply By: Member - Doug T (W.A) - Tuesday, Feb 27, 2007 at 15:26
Davoe
The best way to get the map moving is throw it across the room , though it will stop when it hits the wall
AnswerID: 224356
Follow Up By: Davo_60 (ACT) - Tuesday, Feb 27, 2007 at 18:59
OTT, love the old photo's on you profile.
FollowupID: 485290
Follow Up By: Member- Rox (WA) - Tuesday, Feb 27, 2007 at 22:13
Love the pic too I hope you don't get done for not wearing a seat belt.
Those coppers will try anything to get a buck or 2
FollowupID: 485364
Reply By: Willem - Tuesday, Feb 27, 2007 at 20:24
Good one Davoe...now you can really go out and get lost....lol
AnswerID: 224425
Reply By: Pilbara Wayne - Tuesday, Feb 27, 2007 at 20:31
Hi Davoe
If you dont want to change back and forth between NMEA and Garmin modes on the Etrex, you can go into OziExplorer configuration and on the COM tab place a tick in the "Use PVT for Garmin instead of NMEA". Change the Etrex to "Garmin" mode and then it will work in moving map and be able to upload and download waypoints, routes etc.
This might be easier than swapping between the two all the time. I know my Etrex will work and do both in this mode. This might save the hassle of changing all the time. OziExplorer will inform you if it wont work. More details available in the OziExplorer Help file if you search for "PVT Garmin".
Wayne
AnswerID: 224430
Reply By: Footloose - Tuesday, Feb 27, 2007 at 21:11
Well done. When I first got mine moving my map wasn't calibrated properly. Neither was I ! Went for a drive round the block and missus rekkoned that according to the Lappy we were somewhere in China :)))))
AnswerID: 224440
Reply By: Topcat (WA) - Wednesday, Feb 28, 2007 at 00:33
Glad to see you finally had a win. As with most things these days it all comes down to trial & error!!!!!!!! Cheers
AnswerID: 224493
