Bushman or Mate fridge/freezer
Submitted: Tuesday, Feb 27, 2007 at 11:00
ThreadID: 42755 Views:9968 Replies:10 FollowUps:13
We are tossing between buying Bushman fridge/freezer or EvaKool Mate. I would appreciate any comments from ppl who have already had them for a while in regards to their reliability. Engel seems too heavy, otherwise would be first choice.
Reply By: lambo - Tuesday, Feb 27, 2007 at 11:12
I have an Evakool ED50 about 2 years old. So far we have done 2 big trips, incl Gibb River Road and Tanami, and no hassles with the unit itself. I had a problem with the 12 v power lead and they sent me a new one immediately I called them. We also use it at home all the time for spare freezing capacity.
Trust this helps.
AnswerID: 224296
Follow Up By: jambar - Tuesday, Feb 27, 2007 at 11:26
Thanks Iambo. We want to use it as a back up freezer at home as well. Mate is only 12/24V so would have to get 240V transformer on top of it. But we like the capacity and light weight.
FollowupID: 485148
Reply By: steve&anja - Tuesday, Feb 27, 2007 at 12:07
A mate of mine runs a camping hire business in Darwin, he hires out evakool fridges and swears by then.
The only comment he makes is they don't like trailers, Have a look at trailblazer as well.
Cheers Steve Top End Explore Tours
AnswerID: 224304
Reply By: Gronk - Tuesday, Feb 27, 2007 at 13:09
Thing I didn't like about the Evakool was the tacky little 12V socket on the side . Prone to damage down there I thought ??
Things I liked about the Waeco ( which I bought ) was the ease of plugging it straight into 12 or 240 without the worry of external power supplies, the low weight and most importantly the useability of the inside( this will vary from person to person )
BUT, I keep hearing good reports on the Evakool ( don't know about the Bushman)
Engel don't make a 60 litre in a "normal" size and they are HEAVY, but would be the most reliable and popular..
Except for the weight, if I had more money, it would be a Trailblazer for me !!!
AnswerID: 224311
Follow Up By: jambar - Tuesday, Feb 27, 2007 at 14:07
Thanks Steve and Gonk, you both mention traiblazer. Haven't come across that one, only been investigating them for a short time, must check!
FollowupID: 485204
Follow Up By: Member - Au-2 - Tuesday, Feb 27, 2007 at 15:55
A tale with a moral. Prospecting up Georgetown area Qld ,sometimes on the dirt roads u gotta take your false teeth out let alone the property tracks. One particular day Ozesheila ( yeh she's my lovely wife) decided to stay back at camp , luckily, so I went off with the dog Cooper to a new area. To much study of the terrains geoligy instead of the speed of track , came around the top of a hilly corner and Shiii , Sorry, to put it politely, Criiiikey :)) there were 2 sharp shale ridges across the track about 40cm high with rounded tops. Crikey I thought :), I jabbed the brakes to compress the front, bow down then bow going up just before impact, I caught a glimps of the moon thru the windscreen just as the back wheels hit, then stern up and bow down , then thru the windscreen the second ridge , no need for another compression brake couldn't anyway as by now my feet were up around my nesk and and we were coming down frount wheels first anyway. As luck has it right on the right spot before the 2nd ridge . Front compression then the rear wheels hit the ground then silence, we were airborn again clean over the 2nd ridge, then the trouble started, we were on the down hill slop with the bow up and couldn't see where we were going to land. The truth is I was hanging on for grim death. After a lot of bouncing and rolling we stopped , checked every thing out underneath, just a few dings here and there , then I remembered the 80Ltr Engel straped down in the back, Ozi's pride an joy . I thought , "Oh well it'll be dead ", I opened the back it was still going, half wot was in the Engel was out an half wot was out was in including the prospecting pick,( I didn't clip the lid latches down last time I pulled a drink out or zip up the insulation cover ) , its head over the edge and the lid closed on it with the handle sticking out, looking at me if to say "is it safe to come out now". I said to the Pick "You been trying to join the mile high club or sumthin wif our fridge" an the pick said "no she's to cold for that, jes given it a cuddle. When I got back Ozi said how did it go I said ask the pick. I didn't tell her what happened but I guess she'll read this an I'll get a ribblng. That fridge takes a pounding over heavy rutted dirt roads every time we go prospecting and just keeps on going . The Moral of the story is: " If a pick can't stuff an Engle noffin can." Buy an Engel, u won't go wrong. " :)
Pickhandle
FollowupID: 485222
Follow Up By: jambar - Tuesday, Feb 27, 2007 at 16:04
Wow, pickhandle, you literally took my breath away, got me dizzy!!! Must say you made your point about Engel....
FollowupID: 485228
Follow Up By: Member - Au-2 - Tuesday, Feb 27, 2007 at 21:55
Yeah well.....what can I say six months after the event? No wonder Cooper looks askance every time we hitch up the trailer . I don't think I would have been amused if I HAD been there! I realised on that trip that I was getting a bit old to really enjoy bush bashing the way we did twenty years ago. Not that we did much b-bashing. One little blue eyed blonde hugging a cabbage patch doll while yelling, "Daddy, don't go faster," and similar phrases from three rambuctious boys, makes for very sedate driving. Maybe I should drive more often.
OzeSheila.
FollowupID: 485355
Reply By: Member - Franga (QLD) - Tuesday, Feb 27, 2007 at 14:38
Hi Jambar,
Look up post 10008 in archives, lot of good info on the Trailblazer.
Absolutely worth considering
AnswerID: 224339
Follow Up By: jambar - Tuesday, Feb 27, 2007 at 16:11
Thanks, see what you mean, the bulkiness may be a prob, but will have to check it out. Back to the drawing board :)
FollowupID: 485232
Follow Up By: Graham & Lynne - Tuesday, Feb 27, 2007 at 21:40
I have 20+ year old t/blazer & have recently installed 3 extra cooling fans how do I access 'post 10008'.
FollowupID: 485352
Reply By: Member -Signman - Tuesday, Feb 27, 2007 at 15:12
The Bushman used to be a fair unit- when it had the Danfoss Components. It now has a GE?? unit, which is consider inferior to the well proven Danfoss or Sawafuji units. The specs in the brochure (incl. the ADI tests claim) are when it was Danfoss driven.
Also, just a personnal issue, the lid hinges 'sideways' as compared to most other brands and models. This can be a hassle to access dependant on where and how the fridge is mounted. Also, to achieve a reasonable 40l capacity, you need the optional 'collar' which does make it quite tall.
They are made in China (if that makes a difference) with a blown plastic outer.
I'd stick with the more popular Engel (or that other one- starts with W)
AnswerID: 224352
Follow Up By: jambar - Tuesday, Feb 27, 2007 at 16:14
Hi Signman, appreciate your post, the only one so far about Bushman, doesn't seem to be too well known. We didn't know anything about it till few days ago, there is a demo model for sale cheaper and with full warranty, that's why we were considering it. From your post the quality sounds a bit suss though.
FollowupID: 485234
Reply By: Willykj - Tuesday, Feb 27, 2007 at 16:58
Perhaps it's time to let a Bushman user have a say. I have had one for 3 years & it hasn't missed a beat. The 1st trip was to Cape York and last year went away for 3 months camping so the Bushman was used all that time. Also use it when caravaning & at home.
We have been extremely happy with it - it is very effective & is very economical on power. I bought mine because I had 4 mates who all had one - they have had them longer than me & no one has had any trouble at all with their Bushman's.
Willy
AnswerID: 224372
Follow Up By: jambar - Tuesday, Feb 27, 2007 at 17:13
Straight from the horse's mouth, that's what I was after, much appreciated Willy.
FollowupID: 485253
Follow Up By: Member -Signman - Tuesday, Feb 27, 2007 at 17:23
G'day Willie
My comments re the Bushman are from my observations and feedback from both Bushman users and the Bushman distributor. They are only too happy to replace- no charge- the electronics card "when it fails"- which is very reassuring when you're 1 week in some remote area into a 5 week trip.
The switch over to the GE compressor units has only been in the last couple of years only- prior to that they were Danfoss equipped.
The side opening lid is just my personnal gripe, being used to the set up of my own fridge installation.
It's good to know you are happy with your Bushman Fridge.
FollowupID: 485260
Reply By: Mal58 - Tuesday, Feb 27, 2007 at 17:12
Just to balance things a bit (I can see a flame war coming on), I have a Bushman. I bought it in 2000 when it was half the price of the then competition (won't mention names).
We run the Bushman as a freezer (-15 C) and give it a hard time as we swap 4 sheets of techni-ice between it and our old esky pretty much everyday when we travel.
The only problem we had was the power cord came out on some bumpy roads. We got the lead swapped over under warranty. I think the later models have a clip to hold the power cord in.
What we like about it is that you set the temperature and the thermostat runs the fridge to that level. It then cycles a few degrees either side of the set temperature. No guessing like some of the other fridges on the market. No unexpected frozen beer eh ?
It's relatively tough with a metal case and the typical insulated poly carbonate liner. Ours only draws about 3 amps when running, but typical of danfross compressors pulls about 8 amps for a second or two on compressor start up. Good wiring in a car is essential no matter what fridge you get.
I would also recommend a cover to keep the fridge new looking and to add extra insulation.
The fact the lid opens sideways means that you don't need the head room like some other fridges that open lengthways.
All in all, I have no hesitation in recommending the Bushman as a good fridge.
We often see the Melbourne local agent (DP Refrigeration) at the 4wd shows and the owner remembers us. Pretty good customer relations if you ask me.
But like a lot of things, a lot comes down to personal taste, and it is 7 years since we bought ours. In that time both the technology and the market has changed.
So it probably pays to do a bit of research and then determine what has improved and what hasn't and then decide.
Confusing isn't it. Best of luck.
Mal
(Wishing I was out on the track)
AnswerID: 224378
Follow Up By: jambar - Tuesday, Feb 27, 2007 at 17:58
Mal,
Thanks for the reply. I'm like you - warming (perhaps that should be COOLING ) to the Bushman for much the same reasons that you would recommend it . Seems like a pretty neat unit with some very inovative ideas incorporated and good backup. I also like the digital temp contol for the same reason as you and it is comforting to know that under the temp control there is a manual switch that will allow the fridge to operate without a thermostat.
happy holidays mate!
Alan & Barbara
FollowupID: 485271
Follow Up By: Troo Bloo - Tuesday, Feb 27, 2007 at 23:38
HI
I own a bushman and agree with everything Mal58 has said.
I have owned a Bushman for 3 years now and i use it flat out and i havent had a problem with it, does everthing i want. I havent owned any other fridge and cant comment on there performance, i suggest you only listen to people who have actually owned and used a product.
I travel all over the goldfields around Kalgoorlie with work and take my fridge in the back of the ute. I only have one battery, but never stay long in one spot. I highly reccommend a bushman fridge, as it for me was not to expensive and has never let me down.
Troo Bloo
FollowupID: 485396
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Feb 27, 2007 at 21:24
Hi jambar
When did you need your new fridge ? We have completed our full test on the sidewinder 10/40 and will release them at the end of April 2007.
Derek.
AnswerID: 224446
Follow Up By: jambar - Thursday, Mar 01, 2007 at 09:43
We've ended up buying the Bushman (need it soon). Thanks to everyone for the feedback!
A & B
FollowupID: 485677
Reply By: steve&anja - Tuesday, Feb 27, 2007 at 21:42
Check out the trailblazer site.
www.norcoast.com.au then click on service,the prices are well comparable to evakool.
AnswerID: 224453
Reply By: dj Patrol - Wednesday, Feb 28, 2007 at 13:25
I have had my Bushman for about 5 or 6 years and it always has worked fine beer right temp all the time or you can use it for a freezer.Only draw back is my plug I have had to tape in as it comes loose. Overall I would buy another also I got a larger lid supplied with mine and its good to hav the extra height an room.
djpatrol
AnswerID: 224554
