Towing a boat up the Cape???
Submitted: Tuesday, Feb 27, 2007 at 16:13
ThreadID: 42763 Views:8678 Replies:10 FollowUps:13
Just in the process of purchasing a new boat. My partner and i are taking off travelling for 12 months and we hope to do the Cape. I have read thousands of articles about how good the fishing is up there! Is there any chance of towing a boat up all or some of the Cape? The trailer will be around 5 metres long. The trailer itself will be an off-road version with extended drawbar, and raised suspension and bigger tyres. Dual Cab Diesel Hilux will be the tow vehicle.
Appreciate any help or advice!
Reply By: handy - Tuesday, Feb 27, 2007 at 16:35
plenty of people do it, take your time getting there and you will be right.
you will regret not taking it. cheers
AnswerID: 224366
Follow Up By: Rik - Tuesday, Feb 27, 2007 at 17:55
Thanks mate
FollowupID: 485267
Reply By: Member - andrew B (Kununurra) - Tuesday, Feb 27, 2007 at 17:10
Gday Rik
Although I haven't been to the Cape - I managed to get the 5.2m boat in my rig pics up to Kalumburu last year and I would have no hesitation in tking it up again given half the chance.
Taking it easy and low tyre pressures is the best tip I can give you.
Cheers Andrew
AnswerID: 224377
Follow Up By: Rik - Tuesday, Feb 27, 2007 at 17:57
Andrew,
The photos look great. Did you have any trouble with the hull of the boat rubbing on the trailer at any stage, if so what did you do about it? Thanks mate
FollowupID: 485269
Follow Up By: Member - andrew B (Kununurra) - Wednesday, Feb 28, 2007 at 07:40
Gday Rik
Had no problems with rubbing....that I'm aware of anyway! The boat is fully supported along the keel, and there is a couple of mm play to the skids. With a tie down strap on (not too tight) it sits perfectly, the skids have been scribed to the hull so they touch for the entire leangth. They just have the std blue teflon glued and screwed to them, I thought about carpet, but filled with Quartzite dust and sand I thought that would become very abrasive.
Cheers Andrew
FollowupID: 485424
Reply By: _gmd_pps - Tuesday, Feb 27, 2007 at 17:44
Rik,
go for it .. you don't have to go through the gunshot :)) ...
I will take my boat on a custom trailer ... sitting at the cape on land
is only half the fun ...
on thing though: Be VERY !!! carful when you have rollers on your trailer.
My insurance company has explicitly ruled out damage to the hull when the
boat sits on rollers off road. I told them that I will go off road with the boat
and they are fine as long as the boat sits on skids. The rollers will puncture
the hull (fiber or allu doesn't matter). Skids are a pain for retrieval (launch
is usually easier) .. you need more depth which is a problem at times ..
so I have decided to do a combination .. I have rollers for lauch and retrieval but
can lift up a frame with skids through hydraulics that the boat sits completly on
the wide skids (off the rollers).. the frame is pivoted in the front and lifts only in
the back which gives me an additional advantage of getting the drive leg a bit
further off the ground .. am currently working on the plans with my trailer
builder .. looks like I am getting the suspension from QLD .. it's a 6 wheel independent suspension with load sharing airbags and shocks and custom hubs
for my 8 lug wheels and disc brakes all around ...
it's a lengthy project to get this the way I want it, but I have given me another 2 years to fine tune before we take off for good .. I have the boat and am working on the suspension at the moment .. actually getting a stub axle made to hold my
dually tires, the axle being strong and long enough under the pressure of a 6 wheel setup .. I do not want to go straight axle .. IS is much better ...
think very carefully about the roller thing .. it will haunt you on corrugations if
you don't take precautions.
good luck
gmd
AnswerID: 224384
Follow Up By: Rik - Tuesday, Feb 27, 2007 at 18:01
Few questions mate.
How big is your boat?
The boat i am taking is only 4.7 metres. Also, if you don't mind me asking, how much will the trailer cost to have the dual system, unfortunately for me the hydraulics sound expensive. The trailer i was looking at was a Mackay Multi Link ON ROLLERS! My previous boating experience is why i wanted rollers, however, i have never taken a boat off road.
I really appreciate your help and advice. I'll be ringing the insurance company tomorrow.
Thanks again
FollowupID: 485274
Follow Up By: _gmd_pps - Tuesday, Feb 27, 2007 at 18:19
Rik,
cost of the hydraulics is not really an issue... with a small boat like yours
a bottle jack for 40$ will do the trick and a few bolts to hold the lifted frame ..
it's a manual solution though but simple and you only need to do that for
the long runs anyway ... or you go skids all the way, which is a better idea
in your case I guess ... your boat is light and will go onto the skids easy ..
my boat is 6.4m fiberglass with a Mercruiser V8 .. 1.5t dry and 450l of petrol
and 300l of water when filled ... width is exactly 2.50m (legal width)
the trailer is totally custom with a box section in the front (can be set on legs
and taken off). It contains an outdoor kitchen with BBQ and housings for
all sorts of gadgets ... I have a budget of 25K for the trailer ..
my hydraulics are driven from a 6hp Robin motor which I also use for the
hydraulic winch. I use the winch to pull the boat onto the trailer ..
the winch is mounted on the front of my vehicle and I also have a receiver
hitch in the front so I can push the boat into the water ..
also an extendable draw bar that I do not have to drive too far into the
water especially on beach launches ...
The roller thing was something my insurance broker mentioned to me
from experience with previous cases .. my policy contains off road use
of the trailer as long as everything is legal of course ..
I expect the chassis of my trailer to be ready sometime June/July for
a first run before I start designing the kitchen etc.
good luck
gmd
FollowupID: 485283
Follow Up By: handy - Tuesday, Feb 27, 2007 at 18:38
rik make sure you get a decent outboard leg support that goes from the leg to the trailer, you can get them at bias boating or whitworths.
i have got the spring type one and it does a good job. cheers
FollowupID: 485287
Reply By: Crackles - Tuesday, Feb 27, 2007 at 17:44
Rik to work out where you could go we'd need to know what size boat & motor, fibreglass or alloy??
Cheers Craig.........
AnswerID: 224385
Follow Up By: Rik - Tuesday, Feb 27, 2007 at 17:59
Craig,
the boat is 4.7 metres long, 2.15 wide, with a 60HP on the back. It is all 3.00mm alloy! If you can help me to where i can find my metre long Barramundi it would be greatly appreciated!!
Thanks mate
FollowupID: 485272
Follow Up By: Footloose - Tuesday, Feb 27, 2007 at 19:30
Don't forget the offocial Barra season. Once you get a decent fish on , get it in before the sharks and crocs get to it before you. I've had it happen several times when fishing from land up there :)))
FollowupID: 485294
Follow Up By: Crackles - Tuesday, Feb 27, 2007 at 20:01
Plenty of people are taking very big boats as far as Weipa.(twin 100hp) The road has improved to the point where if you set the trailer up properly & take it easy you shouldn't damage the boat or trailer too much. Further north the corrugations in the road require a bit more preparation.
When we went up we had fitted to the trailer independant coil suspension with shocks & 14" heavy duty tyres. A pair of slides were fitted to support the boat better & carried a set of rollers to put on the rear of the trailer when we got there to make launching easier. (lifted with a high lift jack) As it turned out we only used them at one camp as most beaches & rivers had reasonable access for a medium size tinny with a 30 HP.(Hornet) Many up there took the motors off to avoid tearing the back of the boat out but we had a brace made to support the motor in a horizontal position held with ratchett straps. We put carpet strips under the slides & bow to minimise rubbing. Stones being thrown up off the car sand blasted the front of the boat & we had to fit a rubber shroud around the shocks to stop them being peppered by the rocks. We lost the number plate & smashed the tail light assembly off so I'd remove them when you hit the dirt & put them back on for civilization. A treg coupling was fitted for better articlation.
The longer draw bar on boat trailers can cause issues on some of the narrower tracks like the Telegraph, Frenchman's & Jardine river mouth.
Regulars to the Cape we met up there had fitted extra long leaf springs with greasable shackles but by far the most popular was to put the boat upside down on a heavy duty box or camper trailer but I'd be thinking yours is a little big for that.
Where can you go?.......For a boat of your size probably as far as Weipa & out the other side to Portland roads but not via the Frenchman's track. The Hey river & it's tributries has some excellent fishing as do many of the reefs offshore. Normally during the dry season the West of the cape is fairly calm with the East being particually windy. Look for a magazine called the 'Northern Fish Finder'. You wont be dissapointed :-)
A V nose flat bottom alloy boat with a motor you can lift is ideal for the Cape as it gives you access to the more remote areas but there's still plenty off fish to be caught out of Weipa.
Now for the 1.2m Barramundi. You will find it swimmming in a little creek at the southern end of Chilli beach. The bastard rolled off my hook as we attemted to net it :-((
Cheers Craig...............
FollowupID: 485303
Follow Up By: Member - Beatit (QLD) - Wednesday, Feb 28, 2007 at 09:16
Craig,
They seem to have a habit of doing this, there is a big one in the Ord with my hook in it. Did you sack the decky?
Kind regards
FollowupID: 485440
Follow Up By: Rik - Wednesday, Feb 28, 2007 at 09:32
Thanks very much everyone, your advice is very VERY HELPFUL! Firstly, Craig, what sort of trailer did you have? I am looking at a Mackay Multilink trailer, but they can spec it up to a kind of off road version, it is still leave sprung though, with no shocks. It will have bigger tyres on it than standard. Unfortunately the boat is too big to put on the roof of the vehicle or box trailer, also the motor is far too heavy for me to be able to lift off.
The other thing i have been thinking about is a full cover for the boat that will come right down to the trailer at the bow. I have never had a boat with one before and some people swear by them yet a lot of people seem to swear at them. I have a couple of reasons for trying to get one, security, and also to protect the bow of the boat from the stone chip issue you mentioned, also to keep dust and rain out of the boat and contents.
If i was going all the way to the tip, is there somewhere, say in Weipa that i could leave the boat and trailer for the trip up, and then pick it up on the way back?
Sorry for all the questions, hope you don't mind!
As for your 1.2 metre barra at Chilli beach, if i get him i will gladly send you a photo or too!!!!
FollowupID: 485443
Follow Up By: Crackles - Wednesday, Feb 28, 2007 at 17:11
Not sure of the trailer brand Ric but was only a fairly light weight unit, certainly nothing special. The leaf suspension was unbolted at the U bolts & a replacement independant coil set rolled in leaving the top half pretty standard. For rough roads the way I see it you need a long travel subtle spring whether it be coil or leaf (not slipper) & a shocker to stop the rebound. On boat trailers there is very little space to fit the shock without jacking it up too high. The oversized wheels will help with ground clearance & keep the bearings cooler but does make it harder to launch.
If you like to keep your boat shiny this trip may test your metal as the rocks will chip the trailer & boat somewhat but some sort of stone gaurd on the bow would be a good idea, possibly something replaceable like shade cloth as it will take a beating too. (maybe bigger mudflaps?) Will no doubt be several options for boat storage in Wiepa. Possibly ring the caravan park (only 1 in town) for some ideas.
Look forward to the photo of MY barramundi ;-)
And no I could't sack the deckhand as he helped net the coral trout :-))
FollowupID: 485519
Reply By: pete - Wednesday, Feb 28, 2007 at 14:00
Hi Rik
I managed to tow a 3.7 metre tinnie with 15 hp on the back to Weipa a few years back - on a Mackay trailer that I had put a Landcruiser axle on with leaf springs - the rubbing of the skids on the underneath is a real concern - to the point that the boat needed some creative welding some time later where it had worn through. I was thinking of marine carpet over the skids to minimise this next time. I am planning a trip into Arnhem Land with a 4.75 metre 60 hp on a commercial off road boat trailer - although I have had a few problems with this trailer without going too far off road - the support post for the winch has cracked through, as has the top section of the post. Anywhere there is potential for weakness would be worth strenthening before you go rather than worry about getting it fixed halfway to the top. In terms of tie down - I'm thinking about turn buckles to minimise movement, but I hear stories about not having the boat too tight to the trailer? Still some way from having a setup that I am completely happy with despite paying extra for a so called "off road" boat trailer that was actually promoted a few years back by some TV "fishermen" - I should have known better......
AnswerID: 224562
Follow Up By: Rik - Wednesday, Feb 28, 2007 at 16:29
Pete,
Do you know what thickness the bottom of your first tinny was? Was it 3.00mm? The trouble i am having is trying to find the right trailer for the boat. No one seems to cater for the off-road market.
The trip to Arnhem Land, will the boat be on skids or rollers? The original trailer i was looking at was going to be a roller design for ease of launch and retrieve. However, since posting my question here i have changed my mind somewhat!
The boat size you are taking to Arnhem Land is nearly identical to the one i am talking about.
Do you mind telling me what brand the trailer is you are using currently? I have certainly struggled attempting to find the right trailer.
Appreciate your help greatly Pete
cheers mate
FollowupID: 485513
Reply By: whyallacookie - Wednesday, Feb 28, 2007 at 14:18
With what you are looking at spending on your trailer would it be better to buy a smaller tinnie to take? Then you could perhaps look at a camper trailer for more comfort and stick the tinny on top. (You could always do charters in the bigger areas)
AnswerID: 224570
Reply By: Rik - Wednesday, Feb 28, 2007 at 16:32
Unfortunately, the boat is the ideal boat for fishing in all the areas that i hope to fish, from Port Phillip Bay in Victoria, to the Cape, to the Territory and everywhere between! I did contemplate charters, but with the length of our trip, and the time i HOPE to spend fishing, it basically works out cheaper to buy the boat! Then it gives me the freedom to go and do as i please.
Thanks for your thoughts though!
AnswerID: 224590
Reply By: Sea-Dog - Wednesday, Feb 28, 2007 at 17:29
If you have made it to Weipa then you will make it to Seisa also....
I would recommend a boat cover and also a stone deflector as the roads will pepper your boat as you tow it along..
You will be hitting a million corrogations so you will have to have the set up ready for that!
In short you will have to have the suspension on both car and trailer pretty much spot on... full cover on your boat (if you love it the way I would) and stone deflector on the trailer.. and brakes on the trailer..
Take it easy and just take the Developmental Road up the guts.. Of course you can take diversions but you would not want to be doing the telegraph track with a 5 meter boat on the arse of your car.. although i am sure you could do that too if you were keen enough!
I wish I was coming with you.. the fishing was pretty good when I was up that way on a charter! ........... bait up and cast out.. wait 10 seconds while scratching you bum and then bang!!! fight fish for another 15 seconds before BANG!!!! whatever you hooked the first time gets smashed by something bigger!!! lots of fun to be had!!
AnswerID: 224601
Reply By: FJ40Baz - Thursday, Mar 01, 2007 at 12:48
crazy man the cape is known to have the worst corrugations in oz and after 25 trips to the cape i agree its not too bad early in the season but at the end its sad also believe it is better to hire a tinny for a couple of days you will tow the thing for a long time to use it a little bit over the 12 mths and it will cost more in fuel towin it around and it is always on your back you cant explore the cape with a 5 metre trailer you can touch the surface but to see it all well where do ya leave it an if ya wanna catch fish be in normanton when the wet starts no one in town its awesome 800k from cairns all bitumen to karumba then go to burketown
AnswerID: 224750
Reply By: pete - Saturday, Mar 03, 2007 at 21:13
Rik
A couple of companies worth a look:
www.easytow.com.au/
http://www.ruhletrailers.com.au/platinum.htm
Mine is a Ruhle trailer with skids - great concept, but some teething problems as mentioned. Check out Scott Mitchell's article about his trip up north a year or so ago in Flylife magazine - using a custom made Easytow and wrapping evrything in cling wrap. My first trip up north was with a Stessl Edgetracker - thinner hull than my current Hornet.
Pete
AnswerID: 225132
