GU 4.2td H/Duty Clutch
Submitted: Wednesday, Feb 28, 2007 at 13:15
dj Patrol
What are all you guys fitting Heavy Duty Clutch Kit Nissan GU 4.2TD as
mine has karked it at 106000km .
Daiken H/D or Safari H/D
Or anything other which is best URGENT help. Tows 2 ton van most of the time but treated with the utmost respect.
djpatrol
Reply By: Tony - Wednesday, Feb 28, 2007 at 14:55
I have just had a Daiken H/D clutch fitted at 180,000k as was recommended by a good mechanic. My camper is around 1700kg max fully loaded.
The Safari one is recommended for comp use with big motors.
224578
Reply By: Batman69 - Wednesday, Feb 28, 2007 at 16:20
Reply By: BGJ - Wednesday, Feb 28, 2007 at 17:51
Had Daiken H/D clutch fitted to my 4.2 GU with after market turbo fitted. Tow 2.5t van with no problems. Have only done 25,000 since fitted with about 11,000 towing the van.
224605
Reply By: Geoff - the first - Wednesday, Feb 28, 2007 at 19:52
dj
I've done 50,000km on a Daikin h/d. No real heavy towing, just camper trailer stuff.
It's as good as the day it went in. Smooth as............
Geoff
224638
Reply By: Trevor R (QLD) - Wednesday, Feb 28, 2007 at 21:08
Daiken H/D, fitted to
mine 20K ago and no probs. I got 280K out of the original so if I don't get 150K out of this one I will be ticked right off.
Cheers, Trevor.
224650
Reply By: Member - Troll 81 (QLD) - Wednesday, Feb 28, 2007 at 22:01
Daiken H/D for me as
well original lasted 140k cost to do was around the $1000 mark
224671
Reply By: Member - Vincent A M (NSW) - Thursday, Mar 01, 2007 at 17:06
i have always fitted a centre force clutch in my nissians (2) 6x4 that works & tows all the time & have never had to replace one. My old 6x4 nissian did over 500,000klms with it & towed up to 4500kg & 1500kg on its back
224778
