Repacking 105 series / 78 series Wheel Bearings
Submitted: Wednesday, Feb 28, 2007 at 16:45
spliney
Dear All
My standard 100 series (105 series?) is due for a 200000km birthday.(I think it's pretty much the same running gear as 78 series.)
Does anyone have any extra advice before I make a start on the following jobs? I've not done any of these on this vehicle before - but all look straight-forward in the guts book.
re-pack wheel-bearings
flush and replace brake fluid,
flush and replace coolant,
oil change - manual transmission, transfer case, front and rear axles,
Thanks and regards
Spliney
Reply By: Sea-Dog - Wednesday, Feb 28, 2007 at 17:03
Wheel bearings are pretty straight forwards... but it is
well worth the effort if you have the hub that far apart to check out for oil leaks etc from the swivel hubs and inner axle seals...
224598
Reply By: Chucky - Wednesday, Feb 28, 2007 at 18:06
Make sure use a 54mm tube socket for the bearing nut. I've seen too many butch jobs where people use a hammer and dolly.
And I would also look at putting in a swivel hub gasket set too. For 80bucks and this would include the turning bearings.
Good time to check the C.V's and replace if they are worn as
well. Keep the best one for a spare.
224610
Follow Up By: Tony - Thursday, Mar 01, 2007 at 10:40
As
well as all inner axle oil seals and hub seals.
485686
Reply By: Member - DOZER- Sunday, Mar 04, 2007 at 20:53
check cam shims, might save you heaps of foldy stuff. While there doing wheel bearings, id pull the c/v's out and repack them.
225290
Reply By: Member - Phil G (SA) - Sunday, Mar 04, 2007 at 22:52
This LCOOL link may help with the bearings.
Brake fluid - use only the Toyota Dot 3 brake fluid.
Coolant - I only use the Toyota red coolant - saves any issues from mixing coolants.
I use 75/85 oil for gearbox and transfer
and LS90 for both front and rear diffs.
225315
