Batteries??
Submitted: Tuesday, Apr 08, 2003 at 18:40
Johnad
Can anyone help with which battery to chose. So far, ive looked at the Century range, or the exide extreme.
Reply By: Member - diamond(bendigo) - Tuesday, Apr 08, 2003 at 20:16
i use delcor marine for my second batt no troubles yetlooking foward to
easter at jamieson
17158
Reply By: Member - Willem- Tuesday, Apr 08, 2003 at 21:00
Batteries are batteries................choose a N70ZZL 17 plate.
I have a Yuasa/Century auxilliary battery and a Desert King main battery. I run a Rotronics MH10 battery isolator. Everything works OK. The Yuasa is 4 years old and working
The Desert King is 12 months old.Cheers, Willem
Never a dull moment
17167
Follow Up By: Member - David- Wednesday, Apr 09, 2003 at 11:10
I initially had a cheaper 17 plate main battery (Bestco or something like that). It lasted just past the 12 month warranty period, then died. Now I have a Yuasa main battery (3 years) and a Century marine auxillary (1 year old). I use a Jaycar isolator/charging system that came as a 'do your own soldering' kit. No problems so far.
10743
Reply By: Member - Chris - Tuesday, Apr 08, 2003 at 21:00
Johnad, you after advice on a starter or deep cycle battery.
I use an Overlander starter which have been brilliant and an AC Delco for deep cycle, been through two Delcos in four years but that's probably my fault with lack of maintenance and storage in hot temps etc.
RegardsLove the bush.
Chris
17168
Reply By: Voxson (Adelaide) - Tuesday, Apr 08, 2003 at 21:39
Yep.. The overlander is a great battery.........
I have boiled it so bad that the charge indicator has melted into the acid and it still gives me a start every time i turn the key...
I will replace it with another overlander before i leave on my trip this year..
Regards......_____________________________________________
Countin the days till July 5th. *
Cape York Trip*
17173
Follow Up By: Goodsy - Tuesday, Apr 08, 2003 at 23:54
How did you boil it Voxson??
10728
