Patrol GU 3.0TD Manual Vibration????
Submitted: Friday, Apr 11, 2003 at 00:00
Hi all.
Have had my TD3.0 patrol for about 8 months now..22,000km's.
Started to notice a vibration or resonating sound around the 2500rpm mark. Cruising at 100km/ph can be annoying unless increasing or decreasing speed.
I have a safari
snorkel fitted.
Anyone experiencing the same??? is it normal. Maybe i'm just getting use to the car and being picky...not sure.
Thanks in advance...
Reply By: Tony - Friday, Apr 11, 2003 at 07:38
Andrew sounds like an induction noise, how is your air filter not dirty and in need of cleaning/changing.
17355
Follow Up By: Andrew - Friday, Apr 11, 2003 at 16:26
Tony
Air filter was 1st thing I looked at. No worries there. I have noticed however that air is being sucked in via the join between the side of the engine bay and the pipe leading into the air filter itself!!!!
Looks like it wasn't sealed properly on installation of the
snorkel. Easy to fix and that might be the problem.
10908
Reply By: Member - Melissa - Friday, Apr 11, 2003 at 13:59
Andrew,
Can you be more specific about where the vibration is coming from? If it's the front end it could be the shims/pre-loads need adjusting. GU's to tend to have an inherent front end vibration as a result of this but it can be easily and quickly fixed by Nissan. Ours became apparent at about 45,000 km's and like you came in at cruising speed of 100km/h. Slightly slower or faster and it went away.
Hope this helps.
:o) MelissaPetrol 4.5L GU Patrol &
Camprite TL8 offroad camper
17374
Follow Up By: Andrew - Friday, Apr 11, 2003 at 16:29
Thanks Melissa
have a look at my reply to Tony above.
I'm pretty mechanicaly ignorant so can you tell me more about the shims and preloads you mention. What are they??
10909
Follow Up By: Member - Melissa - Friday, Apr 11, 2003 at 17:30
Sorry Andrew,
I don't know anymore than that, just what the Nissan mechanic told my husband. It was about $100 job, quite common apparently and fixed it. Any decent Nissan mechanic would know what I'm talking about I'm sure.
10913
Follow Up By: Andrew - Friday, Apr 11, 2003 at 22:16
No worries Melissa, I'll mention it to my mechanic next visit..
10925
