Nissan vibration after lift kit fitted
Submitted: Friday, Apr 11, 2003 at 20:41
ThreadID: 4353 Views:2234 Replies:4 FollowUps:8
Have just fitted a 3 inch OME lift kit to my brothers swb 1990 4.2 diesel nissan. We have found a vibration that wasnt there before and so believe its due to the angle of the drive shafts from the transfer case. Assuming that is the correct assumption we need to fit a spacer kit to drop the case. Any idea how much we need to drop it?
Reply By: Member - diamond(bendigo) - Friday, Apr 11, 2003 at 20:49
not sure about fitting spacer kits but if i do a lift at work over 2 inch i always recomend at least at the front to fit caster adjust bushes to the front control arm to diff mount to straighten angles a little better also fit it if people want to fit 33 inch tyres if they scrub on full lock cost of bushs fitted and wheel alignment should be about $350.looking foward to easter at jamieson
AnswerID: 17408
Follow Up By: Goodsy - Saturday, Apr 12, 2003 at 01:02
Do you stay in the caravan park at jamieson. How long have you been going there.
FollowupID: 10930
Follow Up By: Member - diamond(bendigo) - Saturday, Apr 12, 2003 at 01:16
gday goodsy we usually stay at skipworth reserve on the jamieson/woodspoint road.nice the3re and so much to see not far from therelooking foward to easter at jamieson
FollowupID: 10931
Follow Up By: Goodsy - Saturday, Apr 12, 2003 at 02:05
Only asking because I knew the family that use to own it. Spent lots of time up there. And far bit in the pub as well. Nice spot. Love it.
FollowupID: 10934
Reply By: Truckster (Vic) - Friday, Apr 11, 2003 at 21:58
Shorties are notorious for viabrations after lifts... usually you can get away with 3inch!..
Anyway Check the Unis for play/wear, and as Diamond said, Caster kit can do wonders.
Also spacer kit is available, but try these first, or you lose part of the reason for the lift - clearance.
AnswerID: 17416
Follow Up By: Member - diamond(bendigo) - Friday, Apr 11, 2003 at 22:49
what actually is a spacer kit never heard of them where do they golooking foward to easter at jamieson
FollowupID: 10927
Follow Up By: Truckster (Vic) - Friday, Apr 11, 2003 at 23:26
You can lower the gearbox/transfercase down to allow the angle of the shafts to not be as savage.......
Just a flat spacer. I think www.bigballsoffroad.com has them .. Call Liam and ask.
FollowupID: 10928
Follow Up By: Truckster (Vic) - Friday, Apr 11, 2003 at 23:28
I should add its easier to use caster kits to just turn the diffs to change the angles.
FollowupID: 10929
Follow Up By: Member - diamond(bendigo) - Saturday, Apr 12, 2003 at 01:19
yes there not too bad to do caster kits. only been doing suspention for 4 yrs and never heard of spacer kitslooking foward to easter at jamieson
FollowupID: 10932
Reply By: Voxson (Adelaide) - Friday, Apr 11, 2003 at 22:19
Welcome to I have a lifted GQ with a vibration CLUB._____________________________________________
Countin the days till July 5th. *Cape York Trip*
AnswerID: 17417
Follow Up By: Member - diamond(bendigo) - Friday, Apr 11, 2003 at 22:48
love you rig pic mate nothing better than seeing a cruiser being pulled out bye a nissan.and before you all start hehehe im only kidding dont take it the wrong waylooking foward to easter at jamieson
FollowupID: 10926
Reply By: jaycee - Saturday, Apr 12, 2003 at 15:53
We have dropped the transfer case 20mm (because thats the thickness of the plate that we had sitting in the garage) and bingo, vibration gone. Obviously our assumption was correct. Now no longer of the GQ vibration club!
AnswerID: 17467
