More HF Questions
Submitted: Sunday, Mar 25, 2007 at 08:10
ThreadID: 43606 Views:2515 Replies:4 FollowUps:6
With the Barrett 550, how do i set my set for my Selcall ID ? The manual tell how to send 7 receive Selcalls but not how to set it up. Do I need to take the unit to a Tech ?
Vince
Reply By: Member - Matt M (ACT) - Sunday, Mar 25, 2007 at 08:59
Vince,
Short answer, yes. Take it to a tech and have them do it for you.
Matt.
AnswerID: 229561
Reply By: MEMBER - Darian (SA) - Sunday, Mar 25, 2007 at 10:10
No - you should be able to do that in the 'protected menu' - that's what I do in my 950 setup.
Press and hold the menu button......when you get the prompt.......
Enter the factory login 1 2 3 4
Once in, scroll through the settable parameters using the up or down channel buttons (1 and 4). Look for the selcall ID section.
You might have 2 selcall ID's to set - make them the same, if so - at some later stage if using radphone, the second one comes into play and could be changed then.
See how you go............any snags.............you're welcome to email
darian@picknowl.com.au
AnswerID: 229580
Follow Up By: Member - Matt M (ACT) - Sunday, Mar 25, 2007 at 10:22
There you go. Maybe I should have said, 'if you are as useless at these things as I am, then take it to a techo'.
Darian, is it the same set up on the 550?
Matt.
FollowupID: 490362
Follow Up By: MEMBER - Darian (SA) - Sunday, Mar 25, 2007 at 10:38
I've only owned a 950 - not the 550 - but highly likely its the same setup.
FollowupID: 490367
Follow Up By: davidta - Sunday, Mar 25, 2007 at 13:17
The 550 only has provision of 1 selcall.
I had one before the 950, which was before the Icom, so I'm a bit rusty on it, but basically what Darrien said is right.
David
FollowupID: 490396
Follow Up By: Vince NSW - Sunday, Mar 25, 2007 at 16:51
Thanks darin & David
Went in like clockwork. Can't test it at this stage as I have removerd yhe Auto tune & waiting for a 2nd hand multi tap to arrive from Williem, when that in I will see if I can find some one to call me.
Thanks again
Vince
FollowupID: 490418
Follow Up By: Ronnie - Sunday, Mar 25, 2007 at 20:05
Vince what is wrong with your autotune antenna ?
Ronnie
FollowupID: 490460
Follow Up By: Vince NSW - Monday, Mar 26, 2007 at 07:50
The Autotune work well but I am haveing BIG problems keeping the base fitted tightly to the bull bar, Every time I go near rough roads it becomes loose, so have removed at this time. I will look at a mounting bracket for the rear when I have the time.
Vince
FollowupID: 490499
Reply By: Member - Davoe (Nullagine) - Sunday, Mar 25, 2007 at 19:08
with a 250 you pull the case apart (reel easy) and set the 4 dial to your deisred selcal) any one that passed lego 101 can do it
AnswerID: 229649
Reply By: Member -Signman - Monday, Mar 26, 2007 at 09:23
Hi Vince
When you get set up- give me a call- and I'll do Selcall test for you..
MM for contact details.
AnswerID: 229758
