Solar Charger for a satphone battery
Submitted: Sunday, Apr 13, 2003 at 16:30
Mario
G'day all. Here's a curly one for all the techies out there:
I have a Motorola 9500 satphone with a spare battery. While I'm in a vehicle, no problems, I plug it into the lighter outlet. However, when I'm out in remote country surveying or collecting samples for quite a few days carrying the satphone in my backpack I have a problem.
The 3.6v Lithium Ion batteries are designed to discharge at 5% per day. For safety reasons, and in case I find something interesting and need to make detailed reports on scene, AND, I'm out in the weeds
well away from the vehicle for a week or more, I would like the ability to "top up" the batteries. Here's the rub - The solar panel supplied by Motorola is too heavy to carry and far too expensive to buy (almost as much as a new phone!)
So what I need is a small light (fit in a pack pocket or under the top flap)and relatively inexpensive solar panel set up ( I have the gear and skills to construct one to specs or from a kit) that will charge the 3.6V LI ION batteries. I've been told that a "special setup" is needed to charge these particular type of batteries. Is this the case? Are these batteries the same as the usual mobile phone batteries?
Can anyone technically/electrically/solar minded help me out with this problem? Cheers, Mario
Reply By: Bob Y. - Qld - Monday, Apr 14, 2003 at 13:44
mario, Check out Jaycar Electronics for small s/panels, they even have some folding ones. But wouldn't you mount it on top of backpack through the day so you were getting max charge into the phone?
hooroo...
17587
Reply By: Eric - Monday, Apr 14, 2003 at 23:43
Mario.
This type of battery is normaly charged with pulses because that is the fast way of charging but if you are trickle charging you can use a normal voltage regulator. There are 6 volt panel/chargers made for electric fences, that are
well priced. Eric.
17627
Reply By: Darrin - Wednesday, Apr 16, 2003 at 10:52
Sorry I cant be of any help . But if you find something appropriate could you let us all know or notify me at lisadarrin@hotmil.com
thanks.
17749
