stall start on hill?
Submitted: Sunday, Apr 13, 2003 at 23:11
ThreadID: 4384 Views:5627 Replies:12 FollowUps:11
Has attended a 4wd training today and find the stall start technique pretty tricky.
It is very difficult to get up a rocky/muddy hill and even much harder to reverse down. When using stall start technique, the sudden speed picking up during starting could be my biggest concern.
From textbook, yes, it is a useful technique. By in reality, how many people has ever done this ?
Yes, using engine braking to reverse down may be good. But isn't it better to put it in neutral and apply the brake and reverse inch by inch so that you can make sure the wheel placement. Reverse down using engine brake is slow but sometime .......( Not too slow is too fast ! )
Reply By: Simon - Sunday, Apr 13, 2003 at 23:31
Sorry Im confused?
AnswerID: 17545
Reply By: Member - Jimbo (WA) - Monday, Apr 14, 2003 at 00:26
How's it going IAMGQ?
Practice the technique and you will find it second nature and useful. IMO it is THE ONLY safe method of reversing back down a rocky, muddy hill.
"the sudden speed picking up during starting could be my biggest concern."
This technique ensures you don't pick up speed - because you are in low reverse immediately (since no use of the clutch) and therefore you are IMMEDIATELY going as slow as the vehicle will let you without applying brakes. This means you can steer and apply small dabs of brake when and if needed.
Neutral and riding the clutch are the arch enemies of 4WD'ers descending a hill!
Once you are happy with the practical aspects of this technique I am sure you will find it very useful.
Hope you enjoyed your course,
Jim
AnswerID: 17550
Reply By: Truckster (Vic) - Monday, Apr 14, 2003 at 01:26
Its is the best way
if you try to go down a hill in Neutral, and use the brakes,
1) brakes will get hot and could fade to 0
2) if you start to slide, theres no way of using the engine braking to slow you down.
3) inch by inch doesnt always get you wheel placement.
4) Low R *SHOULD* be ok, but of course all depends on the track, conditions, tires, weather etc.
As others have said, its LOTS of practice, or buy an auto :) You dont stall start on a hill :-)
Where did you do the training? Club or private?
AnswerID: 17552
Follow Up By: IAMGQ - Monday, Apr 14, 2003 at 11:11
Thanks Bruce,
The training was held at Australian Automotive Research Center. Although I am not quite satisfied with the course except the stall start part at which I can do alot of practise in a safe environment. It is at Anglesea and it is worth to have a look what research center with offroad environment like.
FollowupID: 11019
Follow Up By: Truckster (Vic) - Monday, Apr 14, 2003 at 12:10
Dude,
If ya like tag along with me to the next Nissan club meeting, and look at it, and if ya likes it, then give it a go. Its in Noble Park, 7.30pm, first Wed in May.
Driver Training is part of the membership of the club. EG Free. But fully accreditted instructors.
Les Miles does the driver training on our club property at Heyfield. You camp there over night, and its a good night too!
You will find it excellent and quite well done. My wife did hers few weeks ago now, and loved it.. Which is good cause she now wants to spend more $$ on the car :D GOTTA LOVE THAT!
FollowupID: 11027
Reply By: chopper - Monday, Apr 14, 2003 at 06:24
IAMGQ once yougetthe nack of it, it will be very easy and predictable.
Using the engines compression is far more flexible that relying on the brakes.
eg, what if there is a relatibvley flat spot part way down the hill, you'll need to engage reverse anyway to drive over it.
If it scares you, that is probably good, you may look twice at an obstacle before having a go at it.
When looking at any climb always ask yourself if you (and your vehicle) are capable of reversing down it when things go awry.
practice, practice, practice
AnswerID: 17556
Reply By: Member - Rohan K - Monday, Apr 14, 2003 at 09:38
IAMGQ, never, never, put the vehicle into nuetral on a steep or slippery slope. Avoid using the brakes wherever possible, and that really does mean wherever possible. The combination of nuetral gearing and brakes (even ABS will lock and loose traction on a steep and slippery slope) can be a fatal combination for your vehicle, you and your passangers. Just don't do it!
The stall-start technique is a little scarey the first few times - yes, the initial lurch forward/backward gets the adrenaline pumping. However, after that first metre or so, the vehicle quickly comes under the control of the engine braking (especially in low first), and you'll be amazed at how much more controlled and safer the decent will be. With a manual, and good low gearing the vehicle will decend more slowly than you could walk.
I used this technique many times in my FJ40, and its actually one of the more fun parts of 4 wheeling.Be good, or be quick.
Rohan
AnswerID: 17561
Reply By: bruce.h - Monday, Apr 14, 2003 at 11:41
iamgq
ihave used this technique hundreds of times &as a 4wd instructor ihave shown people how to do just as many , what supprises me here is not that you are scarred by this process but that the risks of what you sujest as the better option have not been explianed to you with enough information to absalutely terrifie you from using it
once you place your vehicle in neutral you have basicly lost control of it you only need for your breaks to fail & no matter how good a driver you are you will not stop this vehicle just ask the hudreds of truck drivers who have missed a gear going down hill once this happen s you are a passanger along fo the ride ,also the breaks dont need to fail they only need to be wet & that can be enough for you to loose control the other thing that can hapen is that you will lock a break up which can cause the car to slew side ways & roll over,yes it may seem confusing at the begining but i would sujest that you practice this method on a flat surface till it is second nature it can & will save you & your car
& remember that these course should be formulated to the national standards for 4wd training & the course contents has been gone over & over by lots of people withn years of experance & designed to place the maximum emphasis on the safest way in which to enjoy our sport
regards Bruce
AnswerID: 17572
Reply By: Dion - Monday, Apr 14, 2003 at 12:28
IAMGQ,
A couple of years ago, after I had done some training at Peake in SA, I learned how to do stall start reversals. Look, by no means am I an expert at it, but reasonably confident and competent.
After that training session, I was there months later with a private group of individuals in 4WD's, about a dozen vehicles. My Rodeo with this group was the only diesel manual, so I executed stall start reversals with little trouble. What I noticed by waiting at the bottom of the hill, was observing other drivers, who, perhaps had not had any training, get stuck, and then reverse down. Perhaps also by being petrol vehicles, they didn't have the engine compression braking we have with diesels. Because of the sand involved on these hills, they would reverse using neutral and use of the brake. Everytime they felt the vehicle was getting away from them, they would use the brake's, which locked up the wheels easier, because of the little resistance the sand offers. They would then brake to a stop, and then also need reverse to take off again. Anyway the culmination of this braking to a complete stop intermittently is that what could have remained a smooth run up now had lots of holes in the track as a result of the braking method employed. The only reason their vehicles were stopping was because of the depth of the trenches that were being caused by locked up wheels.
Therefore, for the excellent control it offers, and minimum track damage that could be caused, the stall start reversals are definantly the way to go.
Dion.
AnswerID: 17576
Reply By: nugget - Monday, Apr 14, 2003 at 13:08
As you can see from the above resonses it seems to be the best technique. I'll tell you a short story of what isn't the best technique.
A few years back I was out FWDing with a small party of vehicles. We came to a steep descent and we all got out to have a look. The leading Fourby after some deliberation decided to have a go. I enquired as to whether he was going to use first or second low. He gave me a blank stare and proceeded to tell me the only way to tackle steep descents was (this is a true story) to put it in reverse gear with your foot on the clutch and ease your way down with the brakes. If you get into trouble you can then dump the clutch (while in reverse gear) while burying your right foot on the accelerator! Needless to say he used his preferred technique, lost control (with rocks and dust flying everywhere) and hit a tree.
AnswerID: 17581
Follow Up By: IAMGQ - Monday, Apr 14, 2003 at 15:13
Thanks nugget. It is indeed a very interesting story! I would love to meet this such a unusual amazing 4wdriver !
FollowupID: 11043
Follow Up By: Truckster (Vic) - Monday, Apr 14, 2003 at 22:00
Believe it or not thats how they do it in the USA and train people on the Rubicon!
Ive also heard of people doing it here, but at $4000 for a gearbox rebuild, I'll pass on it thanks.
FollowupID: 11064
Reply By: Member - Ray - Monday, Apr 14, 2003 at 17:43
NEUTRAL means 'ANGEL GEAR' and thats who you will be talking to if you try that method too often .
AnswerID: 17600
Reply By: Rob from Cairns Offroad Training & Tours - Monday, Apr 14, 2003 at 20:23
As a Nationally Recognised 4wd Instructor I have taught hundreds of people this very safe method of reversing out of a difficult hill situation when you either run out of power or run out of grip. I must say tho that the ease of the recovery varies greatly from vehicle to vehicle. Diesels are by far the safest due to thier high compression and very low gearing.
The scariest ones are fuel injected petrols as when stalled they seem to have a lot of unburnt fuel in thier phlenum? chamber or inlet manifold. This causes them to give a considerable jump when the starter motor engages the fly wheel and that fuel ingnites. I recently trained someone in a late model V8 discovery that was very scary. I combatted this by starting the car with more footbrake than usually recommended to steady the initial leap backward. Practice in a safe place, to build your confidence practice while going forward down a hill, stop and then key start until you become familiar with the characteristics of your car.
Cheers Rob Cairns Offroad Training & Tours
AnswerID: 17608
Follow Up By: awill4x4 - Monday, Apr 14, 2003 at 23:44
Rob, with fuel injected vehicles what happens when they stall is that the idler stepper motor automatically goes into start mode which is effectively a means of allowing your motor to start with more revs than the throttle opening usually runs at. This can be demonstrated at any time when the engine is stopped, simply turn the key the engine will rev to approx 2000 rpm then drop from there to its normal idle speed. It is this initial high rev on a stall start procedure which launches the car at the 2000 rpm speed.
There is a way around this and that is to disconnect the idle speed control before you get into the hard stuff. The best method is to allow the car to idle at rest with no load on engine, eg, no lights, no turned front wheels putting load through the power steering, no air con, etc.
Assuming your car is running at optimum idle, usually around 600-700rpm, disconnect the wiring to the idler stepper motor. (usually an easily disconnected wiring plug) turn off motor then restart. The motor should now start at 600-700 rpm as the stepper motor can no longer function as an easy start device. This method makes fuel injected vehicles much easier to use in stall/start methods.
Remember when you're finished for the day to reconnect as when you go to start on a cold morning you're effectively trying to start your car with no choke.
Regards Andrew.
FollowupID: 11068
Follow Up By: Member - Mal - Tuesday, Apr 15, 2003 at 09:56
Rob,
What is the technique for automatic vehicles i.e. LC 100 TD?
Mal T.
FollowupID: 11078
Follow Up By: Rob from Cairns Offroad Training & Tours - Tuesday, Apr 15, 2003 at 10:31
Thanks for that Andrew. Where do I find this motor on most vehicles?
Mal, the beauty of automatic vehicles is they won't be caught in too high a gear and run out of power and with smooth use of the throttle they won't wheel spin. If you have assessed the hill and decided it is do able
and you are then unsucessful - Brake, handbrake on to make car safe. A\C off to reduce revs. Assess the situation - you have driven up, you must be able to drive down using the same route - move lever from drive stright to reverse (never go to park, if vehicle rolls back in park you may lock there) release hand brake slowly and smoothly - gently rlease footbrake pressure so the car goes back as slowly as possible - do not let the car gain any momentum.
Cheers Rob
FollowupID: 11080
Follow Up By: Member - Mal - Tuesday, Apr 15, 2003 at 11:03
Rob,
Thankyou for that info. I assume if the auto vehicle stalls having run out of grunt it's: Brake, hand brake, all accessories off, e.g. A/c, lights, select neutral, start motor, select reverse, hand brake off, slowly ease off foot brake and guide vehicle down slope.
Mal T.
FollowupID: 11082
Follow Up By: bruce.h - Tuesday, Apr 15, 2003 at 11:38
gday guys
also always remember to turn off your aircon becauce if ti kicks in at the wrong time & it lifts the revs it can catch you short or at kleast frighten the c***p out of you
Regards Bruce
FollowupID: 11084
Reply By: StephenF - Tuesday, Apr 15, 2003 at 12:51
Regarding the higher compression in a diesel assisting engine braking, in my experience (owning a diesel car for 22 years) there is very little difference in engine braking betwen diesel and petrol engines. Although the diesel engine has to work harder to compress the air in the cylinder, that compressed air then helps drive the piston down again, cancelling out much of the work done during the compression stroke.
BTW, my car is a non-turbo with a compression ratio of 23:1, much higher than most modern turbos. I previously owned a petrol version of the same car, so if there was significantly greater engine braking with the diesel I should have noticed it.
Stephen.
AnswerID: 17660
Follow Up By: IAMGQ - Tuesday, Apr 15, 2003 at 13:12
Yes Stephen, I have the same thought as you. I drove a Pajero 2.6 petrol before and it seems that the engine braking is as good as my 4.2 diesel now. May be I am still new to my diesel truck but except at 1st low, all other gear is still too fast to go down a hill.
Has anybody ever tested the difference of engine braking between diesel and petrol engine with same engine capacity (e.g 4.2 diesel vs 4.2 petrol ) ?
May be I should start a new thread
FollowupID: 11095
Follow Up By: StephenF - Tuesday, Apr 15, 2003 at 14:40
I should have added that I was talking about normal on-road driving, not off-road.
Stephen.
FollowupID: 11100
Reply By: Phil G - Tuesday, Apr 15, 2003 at 20:58
Nice discussion - just a couple of comments:
Some petrol vehicles (eg V6 Jackaroo) rev at 2000rpm on startup, making the stall start a nightmare - combat this by applying handbrake a few notches when you have the vehicle sitting there on engine compression, just before starting.
Re engine braking, don't forget about gearing. Examples: Nissans have about 30:1 ratio Low 1st compared to Toyotas 45:1, so they appear to have less engine braking. Also, Prado automatics have a 2.7 1st gear versus 4.3 on the manuals. In my limited experience, manual diesels have excellent engine braking when compared with the extreme opposite (automatic petrols).
AnswerID: 17707
