Waeco power pack charging question
Submitted: Monday, Apr 14, 2003 at 20:29
Leroy
Hi all,
I picked up a Waeco batt. pack and was wondering if you can charge it up from the terminals that the jumper leads connect to instead of the cig lighter? The reason I ask is that it didn't come with a manual.
Regards,
Leroy
Reply By: Member - Moggs - Monday, Apr 14, 2003 at 21:52
Leroy, I have a Waeco Thumper. Yes you can charge it from the jumper lead terminals. This is how you charge it from 240 volts with a battery charger. Check out the Waeco website for charging details. They recommend that you do not exceed 14 volts when charging or you will damage the battery (I think that was it, but you better check). I took the safe option and purchased the battery charger from the fridge
shop in
Brisbane that Waeco recommend for the Thumper. In addition, it may be worthwhile to get the fastcharge car kit for when you are travelling. It is direct wired to the battery and charges the Thumper in about 3 hours when on the road. CheersMoggs ( Normanhurst NSW)
17620
Reply By: Member - Moggs - Monday, Apr 14, 2003 at 21:53
I am also pretty sure you can download the manuals from the Waeco site as
well.Moggs ( Normanhurst NSW)
17621
Reply By: Leroy - Monday, Apr 14, 2003 at 22:21
Ah thanks Moggs I found them.
Leroy
17623
