pulling an of road trailer
Submitted: Tuesday, Apr 15, 2003 at 13:20
bill
i have a gu 4.2td usually tow a 17.6ft evernew van. always tow in 4th gear. intend to go bush this year with an offroad trailer loaded all up weight of approx 500kg. feel i should be able to tow in overdrive without any problems with this weight . told overdrive gear replacement is expencive to replace hence the 4th gear job with the caravan... your thoughts please ..
Reply By: Member - Darian - Tuesday, Apr 15, 2003 at 15:19
How many kilowatts do you have in this GU ? 500 kg should be nothing to your 5th gear - bag of feathers.
I have 118 kilowatts in the Jack 3.0 TD and 5th is the go on flat roads.
My campertrailer would be closer to 800 kg I reckon when on a trip (jerries of fuel and
water plus
tools etc and other goodies inside).Love the bush - stuck in the city - help.
17679
Follow Up By: Old Soldier - Tuesday, Apr 15, 2003 at 16:08
I agree with Darian 100%.
I have a V6 3.5 Jack with a similar weight campertrailer and 5th on the flat [and gradual uphill] is a cakewalk.
I have done thousands of k.m. in 5th pulling the campertrailer. No problems.
enjoy the bush
DennisN
11103
Reply By: Truckster (Vic) - Tuesday, Apr 15, 2003 at 17:23
GU's have a weak 5th gear, but mainly the 3.0's.
As others have said, 500kg should be nothing you should hold more than that in the rear storage are!!
bleep 500kgs is 4 and a bit of me... :-(
I would also check the 500kgs of weight, I think you mean more than that!
17687
Follow Up By: Member - Willem- Wednesday, Apr 16, 2003 at 08:52
So we can now start using the new weight measure of TRUCKSTERS !!
"How much does your 4x4/trailer weigh?"
"Oh, about 28 Trucksters."
Hahahahahahahahaha :-))))Cheers, Willem
Never a dull moment
11132
Follow Up By: Truckster (Vic) - Wednesday, Apr 16, 2003 at 11:14
Why not the wife does.....
11138
Follow Up By: Member - Willem- Wednesday, Apr 16, 2003 at 20:28
Sorry Truckster...No offence meant. I just could not help myself:-)
I am in the same category weight and size wise. 6'3" and very much the wrong side of 100K. Everytime the steering wheel rubs my tum I think of going on a diet BUT I just looooove chocolates !Cheers, Willem
Never a dull moment
11155
Follow Up By: Truckster (Vic) - Wednesday, Apr 16, 2003 at 20:33
No offence taken dude!!!!!!!
LOL, wrong side of 100..wrong side of 110, and 119... :(
But I did buy a book Body for Life, changed a mate of
mine from me to (without a lie), nearly body building stuff in 5 months...
Im there, the wife may want to touch me again then, OH THE JOY OF IT ALL
11156
Reply By: Member - diamond(bendigo) - Tuesday, Apr 15, 2003 at 19:22
should be nothing wrong with towing in 5th just dont let the motor labour in top.bit of a
hill put it in 4th.500kg you musnt be taking much to drink then hehehe and enjoy the bushlooking foward to
easter at jamieson
17696
Reply By: Member - Royce- Tuesday, Apr 15, 2003 at 20:11
He He..... we towed an offroad trailer across the Tanimi and then up the Buchanan Hwy with around 500kg. Two teenagers and a better 3/4 in the vehicle. IT WAS A 1984 Subaru! We crossed washed out sandy river beds and made it all the way with only a few mishaps. I did get bogged once in a
creek bed. Unhooked the trailer, hooked up the snatch strap and pulled the trailer out. Then I went to get the family who were having a dip in the
waterhole..................with the drag marks........ going up and over the rise.........from the
water......... hmmmm saltie?
Oh yeah... the point? Ah
well no point I guess 'cos '84 Subes don't have a fifth gear.
Cheers Royce
Royce www.funshow.com.au
17700
Reply By: GOB vic - Tuesday, Apr 15, 2003 at 20:42
i didnt realise ther was a problem with gu 4.2 gear box i have 89 4.2 petrol 5 speed manual tow a 16 ft offroad pop top about 1700kg loaded plus car loaded and use 5 th gear as often as possible without labouring motor and touch wood no problems in about 30000 ks with this van behind and a camper van before have done about 160000ks out of 330000 on clock and no major problems yet 89 nissan looking foward to august and more travelling
17704
Reply By: colin - Wednesday, Apr 16, 2003 at 11:47
the 4.2 has a bigger and stronger box than the 2.8 and 3.0ltr, so towing in fifth even with the caravan on will be no probs, different story with the smaller donks, you get what you pay for. Col
17756
Reply By: Member - Melissa - Wednesday, Apr 16, 2003 at 14:17
Hi Bill,
We tow an offroad campertrailer with our GU St 4.5L Petrol. On highway, we cruise along in 5th...GU barely knows the trailer is there. Trailer is probably closer to 1000kg when fully loaded with all the gear,
water, fuel etc. 500kg's loaded up seems VERY light for an offroad trailer. It would pay to check this (if you can be bothered).
:o) MelissaPetrol 4.5L GU Patrol &
Camprite TL8 offroad camper
17775
Reply By: Bob Y. - Qld - Wednesday, Apr 16, 2003 at 17:24
Bill,
Been advised to only use 5th gear above 80 kmh, whether you are towing or not. As mentioned above, once you hit a
hill,change back to 4th.
As for 5th gear problems, most brands seem to have some problems, as recorded on this
forum, and I feel it's because people are using 5th around the 'burbs. At under 80 kmh. Just my thoughts, and the experience of almost destroying 5th gear in a Skyline
sedan, by running it too hard in 5th up a
hill. Hooroo...
17789
Reply By: David N. - Tuesday, Apr 22, 2003 at 13:15
There was an issue with some GUs on a quality control problem with machining on the 5th gear. (Do a search of the archives)
However most GU 4.2s and all GQ 4.2s have an absolutely bullet proof Gbx and will handle 5th gear all day everyday towing anything up to a 747- unlike many other makes which have a problem with the above!
18087
