91 troopy
Submitted: Tuesday, Apr 17, 2007 at 18:14
tvl
img src="
http://i154.photobucket.com/albums/s266/billy0000/8e315e0e.jpg ">
anyone know what there for??BACK BUMPER BAR ,,WINCH???
Reply By: tvl - Tuesday, Apr 17, 2007 at 18:18
THIS
234020
Reply By: Member - Phil G (SA) - Tuesday, Apr 17, 2007 at 19:36
Mine are used as the centre supports for the tow bar on my 79series.
234036
Reply By: The Rambler( W.A.) - Tuesday, Apr 17, 2007 at 19:53
You may be referring to the 4 bolt holes left where a towing loop is fixed.There is normally a plate bolted to those holes with a towing loop fixed to the plate.It may have been removed by a previous owner or stolen.
234043
Reply By: Peter 2 - Tuesday, Apr 17, 2007 at 19:53
Originally it would have had a loop type recovery point.
As Phil said it is the centre attachment for the hayman reese type hitch, the bolt spacing is also standard to fit a pintle hook type tow hitch.
234044
Follow Up By: tvl - Tuesday, Apr 17, 2007 at 20:09
494952
Reply By: Member - Phillip S (WA) - Tuesday, Apr 17, 2007 at 22:55
I was at the local takeaway tonight and in front was a troopy with the ring bracket still bolted in place....I suppose people remove them as they might interfere with the step as you got in or out.
We get new model toyota's at work all the time but this the first time I have seen this ring bracket fitted.
234101
Follow Up By: Rod W - Wednesday, Apr 18, 2007 at 10:51
Getting out of the back of
mine I was always frightened I was going to step on it and possible roll me ankle.
I seen troopies with that section of the chassis bowed out.
I've built a decent bar set up on the back basically to remove that dangerous loop.
495057
