Degrease spraying the motor & waterproofing?
Submitted: Sunday, Apr 22, 2007 at 20:38
Rowen
Howdy folks, hows things?
Just a quick one if I may. After replacing my fuel pump which was leaking significant oil, I need to spray the engine & surrounds with degreaser to give it a clean. To ensure
water doesn't get where it shouldnt, do i simply cover the distributor cap (fj60 cruiser) and go for it? anything else I should do/ keep out of harms way?
Cheers in advance
Ro
Reply By: Wayne-o - Sunday, Apr 22, 2007 at 20:50
ROWEN,
mate all you need to do is pull of plugs at spark pulg end (one by one so they go back on the right plug) and hit them with WD40 at both ends, as weel unger the dizzy. Covering the dizzy is a good idea but it can cope with a splash as kong as its not direct. hit all ya electrics with WD40, and good opportunity to clean ya batteries, with boing
water, this removes all grime and cleans terminals. Then a can of degreaser in each hand and go for it. Let it sit for 30-60 sec, in this time a small stiff bristle brush is good to remove built up grime, then get the hose or high pressure cleaner under there and drench the whole lot. Worst case seranio, if you get some
water under the dizzy, not biggy, just take it off and dray it, and hit all the terminals with WD40 again. Not a bad idea to do this afterwards anyway, it will give you a better contact, and slow the buildup of crap.
Good luck!
Wayne-o
235184
Reply By: Member - Hughesy (NSW) - Sunday, Apr 22, 2007 at 21:26
Howdy Ro,
As Wayne-o has said no problems doing what you said. I'd suggest that after you've cleaned down the whole motor spray everything under the bonnet with WD40 or similar to stop surface rust. It will smell a bit on you first drive as the hydrocarbons evaporate, but leaves a nice coating over everything to stop rust.
235193
Reply By: ross - Sunday, Apr 22, 2007 at 21:26
I always use the BP 99% liquid hydrocarbons,nothing better.
As wayno says they can take a bit of
water and if they dont the wd40 or some time will dry them out.
235194
Reply By: DIO - Monday, Apr 23, 2007 at 12:50
I know it's all been said before, but don't forget to be careful if you are using a high pressure pump/cleaner. If the
water jet is applied to closely to certain parts of the vehicle/engine, damage can result. eg. electrical components, certain plastic fittings, rubber hoses and belts, shafts protruding from seals (it's the seals that can be damaged -
water penetration) etc. Take it easy.
235277
Reply By: Member - Oldplodder (QLD) - Monday, Apr 23, 2007 at 17:13
Don't forget to cover the alternator too. Wrap it in a bag.
235339
Reply By: Martyn (WA) - Monday, Apr 23, 2007 at 21:56
Rowen,
I use a degreaser called Simple Green which already has an anti rusting compound in the fluid, this stuff for me has always worked a treat and providing you don't use the hose full
bore and force the
water where you don't want it to go you shouldn't have a problem. I do as others and spray some WD 40 around the delicate electrical bits afterwards. Personally I've never bagged anything, I've had Range Rovers and they are the worst for
water in electrics, so far all good.
235437
