which oil to use on gu patrol
Submitted: Monday, Apr 21, 2003 at 17:15
ThreadID: 4489 Views:2891 Replies:5 FollowUps:5
i have a new gu 4.2 turbo deisel i will need to do a oil change possibly wilst im on my next trip to the kimberlys
what oil should i put in it ? anyone know what the nissan service departments use? i whould prefer to go to a local auto shop to get my oil, as i have bugger all confidence in nissan service .
Reply By: Member - Topcat - Monday, Apr 21, 2003 at 19:45
There has been a lot of debate on the best diesel & petrol engine oils in this forum with different opinions all over. However if you go to post ID 2889 in the forum achives you will find a good discussion on it. Hope you don't get too confused. Cheers.Have Wheels Will Travel
AnswerID: 18031
Reply By: Truckster (Vic) - Monday, Apr 21, 2003 at 20:22
Nick on the patrol list has over 530,000klms out of his GQ TD42 using Shell Rimula X in his....
I use Rimula X in my GQ TD42T.. No problems.
AnswerID: 18035
Follow Up By: Member - Topcat - Tuesday, Apr 22, 2003 at 16:04
So do I. Have been using Rimula X for years without any problems.Have Wheels Will Travel
FollowupID: 11354
Reply By: johnsy - Monday, Apr 21, 2003 at 22:52
just about any of the long haul truck oils are suitable i use mobil devlac in mine .
AnswerID: 18050
Reply By: relaxed (Fraser Coas - Monday, Apr 21, 2003 at 23:01
Theratt
I've got the 3lt TD Patrol and I know Nissan in my hometown uses Castrol Magnatec grade type oils in all the vehicles they service. I say type oil because it isn't exactly the Magnetec but something very similar. If your like me and like to use the same oils always and from a local auto shop then the nissan's oil is no good because the distributors only supply it in bulk to the nissan dealerships. You can buy it from them but at an inflated price of course. I rang the Castrol hot line and discussed my needs with them and they suggested the GTX3 would be a suitable oil. So now I do all my own oil changes with the GTX3 even when I take it in for the scheduled services to ensure the warranty. Nissan don't have a problem with me doing the oil changes because I explained that I wasn't in favour of mixing oils even if it is the same brand.
On the issue of what is the best oil. My belief is that just about any good quality oil is good and will prolong the motor life as long as you don't swap viscosities or brands. I have proven this with my past 2wd cars I've owned. They have given me hundreds of thousands kms with no problems at all.
Hope this helps
Relaxed
AnswerID: 18051
Follow Up By: Flash - Tuesday, Apr 22, 2003 at 11:24
Not being picky- just curious...
Why would you GTX3 rather than a DEDICATED diesel oil eg: RX Super, Shell Rimula, Penrite Diesel etc.
Surely oils aint (diesel) oils......
FollowupID: 11329
Follow Up By: Truckster (Vic) - Tuesday, Apr 22, 2003 at 17:39
My Nissan dealer sells Nissan's oils in 5 ltr containers....
Im also lost as to why you wouldnt use a diesel rated oil, also a with a turbo, hope nothin goes wrong, with the way Nissan are with warranties, you could have zero chance.
FollowupID: 11362
Reply By: Member -BJ (Sydney) - Tuesday, Apr 22, 2003 at 18:05
3.0TD uses CM grade oil or you get soot build up . My mech uses valvoline diesel xtra as it is CM grade also uses it in my trucks 1000000 k's between rebuilds, can't go wrong !!!Wish i was still here / Gulf in July
AnswerID: 18114
Follow Up By: sean - Tuesday, Apr 22, 2003 at 20:19
How do I tell if it is CM grade oil - is it written on the container. What does this mean as I have not heard this rating before.
Sean
FollowupID: 11372
Follow Up By: Member -BJ (Sydney) - Wednesday, Apr 23, 2003 at 15:28
Sean it is an API code should be on label . Castrol GTXD has it bottom left check with dealer to get right code it could be CG. Saw it on Yahoo nissan site thread checked archive but could not find it to check
BJ
FollowupID: 11423
