AnswerID: 237039 Submitted: Tuesday, May 01, 2007 at 07:20
Member - Kiwi Kia
replied:
Hi Snowy,
I have not tried the Maxtrax. I do have an air bag and have found it useful but it is NOT a substitute for the shovel. Be aware that they need to have a wide base, some of the earlier narrow ones were ...... dangerous as the vehicle was very unstable on even a shallow slope. I have used air bags to lift vehicles enough to put material under the wheels and lift them back up to 'ground level' after a person has dug them selves down to the chassis rails. They can also be used to do a quick lift if you are 'hung-up' on a boulder or log.
Some air bags just do not go high enough. An air bag under a vehicle with good ground clearance and a lot of
suspension travel needs to go up a long way before a wheel is lifted off the ground. You may reach the limit of the air bag when the wheel has only lifted a couple of inches. Get someone to demonstrate a bag for you so that you can see for your self. They certainly are light weight and easy to use. The carry bags are always to small, trying to put a muddy air bag into a tiny carry bag is a pain in the ...........
Reply 2 of 8
