Waeco CF80
Submitted: Tuesday, Apr 22, 2003 at 08:00
Member - dolfn
Hi the fridge thing again!!!
Has anyone had any experience with the new waeco CF80/110?
Just wondering how the three compartment thing goes?
Is it worthwhile or just a gimik?
Reply By: chopper - Tuesday, Apr 22, 2003 at 12:00
I've got a 110
to be honest i just use it as a big fridge. I have been very happy with the power consumption and especially like the fact that there are four fan settings.
I turn it on a high setting when i'm driving and then set it to economy for overnight.
I do intend to try the freezer idea one day, to date i have only tested as a freezer in the garage
If i take out the divider and run it flat out from 240v empty, the middle of the larger compartment gets down to -18c.
I'm happy with it, and for the price you get a hell of a big fridge.
chopper
18079
Reply By: Brad - Tuesday, Apr 22, 2003 at 12:02
Hi the cf 80 & 110 frides have 3 compartments 1 a freezer 1 fridge and a shelf area for dairy and so on, the devider between the freezer and the fridge is removable but it will not turn it into a full freezer,the reason why is if you look closer at the evaperator plate which is the white panel lining inside the fridge their is only vanes in the freezer area none in the fridge compartment which means the fridge is cooled by the overflow from the freezer,if you you want a real fridge freezer combo look for units that have two thermostats that control both areas.
18080
Reply By: dougie - Tuesday, Apr 22, 2003 at 17:41
Just got back from a trip over
easter. and I have found the only solution.
I have a 70 lt waeco great! but like always, when in and out all day it gets warm and need to run contantly. Bugger the expense!!!!.
Buy a 7o lt 1/2 for veg and friut and
1/2 for the special brown liquid and something wet for the ball and chain.
Then get a 40 lt freezer only or a fridge that will freeze.
when on long trips it will save the cost in bulk meat savings alone.you have got no idea how much a few lamb chops (Frozen) will cost at innaminka or tibbaburra.
18110
Reply By: PETER - Wednesday, Apr 23, 2003 at 06:56
and like me phone 1800 21 21 21 - ask for karyn and get a really good price regards peter
18148
Follow Up By: bruce - Wednesday, Apr 23, 2003 at 10:59
and like me to.....rang last week ..50l with 240v converter for $730 delivered.....wating for the delivery man
11403
Follow Up By: bruce - Thursday, Apr 24, 2003 at 12:32
The Waeco fridge has just been delivered and I have not had a chance yet to check out yet what Karyn described as cosmetic damage...there does not appear to be very much wrong at all...so for a saving of over $300...it will do me...cheers
11465
Reply By: William - Wednesday, Apr 23, 2003 at 18:29
Dolfn spend the extra dollars and buy an Evakool.
18203
