100 td 17inch rims
Submitted: Tuesday, May 01, 2007 at 18:10
Member No 1
what is every one doing for extra rims? factory or is there aftermarket available
Reply By: Member - Cruiser (NSW) - Tuesday, May 01, 2007 at 18:22
Have a look at
Site Link
or
www.roh.com.au/asp/product_catalogue.asp
I am sure there are others out there.
237186
Follow Up By: Member No 1- Wednesday, May 02, 2007 at 04:52
cruiser...both sites 17 inch are for cars...not four 4wd
the 4wd listed are only up to 16inch
498332
Follow Up By: Member - Cruiser (NSW) - Wednesday, May 02, 2007 at 08:20
Member No 1.......... Just had a look at the Mullins site again and the "Explorer RV is available in 17"x8" - 18"x8" - 18"x8.5". The wheel every 4x4 owner has waited for. Big, bold and classy to suit most 4x4 vehicles in the market today"
And on the ROH site click on the Four Wheel Drive section on the sidebar memu and the RTX model is available in 15"x7, 16"x7, 16"x8, 17"x8
Anyway, that was just as an indicator that there are aftermarket
wheels in 17" available.
Hope this helps
498354
Follow Up By: Member No 1- Wednesday, May 02, 2007 at 08:37
sorry cruiser...should have surfed a bit...CSA Site site the 4wd section doesnt show 17 inch but new releases does
and i needed glasses whci i didnt have on for ROH..lol
they also show a new 4wd in their new release as
well as the one for RTX...
but me thinks I only need steel...dont I..swmbo wouldnt appreciate me having a mag floating around the back yard for when I MIGHT get the time to use it lol
498361
Reply By: Member - Cruiser (NSW) - Tuesday, May 01, 2007 at 18:31
There is a set in the Trader at Site Link
May be worth looking at.
237192
Reply By: age - Tuesday, May 01, 2007 at 19:40
No1
I bought one of these as a very good copy of the 17" factory Toyota
wheels that came with my 100 series (Petrol though - not sure if same on TD)
Available in 17 x 8
Site Link
Have to find invoice to remember price - was not too expensive when compared to Wreckers (if you can find one with a Toyota wheel in this size) or genuine part.
A
237220
Reply By: Member. Rob M (QLD) - Tuesday, May 01, 2007 at 20:04
No 1
Don't bother with the 5
wheels and tyres in the trader section as they have been sold.
237233
Reply By: Member - Coyote (SA) - Wednesday, May 02, 2007 at 11:57
I got a set of 17" Steel rims. granted it took me while to find em but they are "king wheels" look just like sunraysias. Got them from a Mob in MLB.. sorry but I cant recall their name, but I guess it help just to know they are out there..
237376
Follow Up By: Member No 1- Thursday, May 03, 2007 at 07:22
found them with google
498628
Reply By: Member - Phil G (SA) - Wednesday, May 02, 2007 at 21:16
Mn1,
Could always go for the cheap dodgy option.
Buy a 5stud split rim (78/79/105series) from with worn 750R16 tyre for next to nothing. Slip it under the rear as your "space saver" spare - so you no longer have a ground anchor slowing the vehicle down in sand. Put your real spare on a carrier or the roof, where you can actually get to it.
To the best of my knowledge, the 16inch rims will clear the brakes on the 100series. The offset will mean the skinny split sits out where your fat tyres do, so its not an issue. The diameter of your 275/65R17 is 790mm - the same diameter as a worn 750R16.
The only other issue to consider with any other spare is whether the wheel nuts are OK.
237538
Follow Up By: Member No 1- Thursday, May 03, 2007 at 07:39
would my standard 16 inch 100 gxl rims fit?
498633
Follow Up By: Member - Phil G (SA) - Thursday, May 03, 2007 at 18:23
I think so, but theres only one way to be sure.
498770
Follow Up By: Member - Phil G (SA) - Friday, May 04, 2007 at 10:12
"would my standard 16 inch 100 gxl rims fit?"
Forgot to say that I'm assuming that they are IFS steel rims.
498944
