AnswerID: 237486 Submitted: Wednesday, May 02, 2007 at 19:51
Member - Dazza
replied:
I've found snorkels to be of use in water crossings, sand and dust.
For water, make sure the installation is water-tight or it's a waste of time. Block the ends and pressurise it to be sure. For water the type of
snorkel probably doesn't matter as long as it is well fitted.
The Safari with it's vertical top section wins in sand and dust.
In sand dunes you will occasionally have the front wheels throw up sand, and turning the cap to face rearwards will stop it going down the spout.
In dust a centrifugal / spinner type cap stops a hell of a lot of dirt before it gets to load up the air filter. It's easy to just empty out a cupful of dirt each evening, and you'll be amazed how clean the airfilter stays.
Dazza
Reply 9 of 9
