Setec power supply in Jayco Caravan
Submitted: Tuesday, May 01, 2007 at 20:11
OldBikerPete
I live in
Melbourne and I have recently bought a 2005 Jayco Expanda caravan which has a 12V combined power supply, battery charger and power distribution system, model ST-35 made for Jayco by Setec. As part of the check-over I have had the 'van connected to house power over a weekend to charge the on-board battery. After a couple of days I checked the voltage at the battery and it was only 12.0 Volts. Followed this back to the controller and found the same voltage at the controller's Bat+ve pin. Disconnected the battery and it still displayed only 12.0 Volt.
This corresponds to a battery which is only half-charged and Setec's spec. which came with the van says it should be 13.7+/-0.1 volt, which is more like it.
Where in
Melbourne, other than Jayco themselves or a Jayco dealer can I take the unit to have the charging voltage corrected?
Reply By: Anthony - Tuesday, May 01, 2007 at 20:26
I would take it back to your jayco dealer. If its out of warranty, I would expect that jayco would still offer to replace the ST35 for little or no cost.
The following is a link to the Setec website where you can download a pdf of the ST35 manual.
www.setec.com.au/pages/st35-II.html
I have found the service crew at Bayswater jayco to be very helpful.
Cheers Anthony
237247
Reply By: Muzzgit [WA] - Wednesday, May 02, 2007 at 23:48
First check the circuit breaker. Jayco put these in the silliest
places and the little button gets accidentally bumped and hey presto, you have no 240v going to anything.
237576
