AnswerID: 237325 Submitted: Wednesday, May 02, 2007 at 01:09
Tim HJ61 (WA)
replied:
Gerry,
I have a 24v Landcruiser import. There is plenty of sensible information around about what to do, or more partcularly what not to do. Try searching for 24v electrics on this site.
Just briefly, you CAN draw 12v from one of the batteries, but what you must NOT do is not recharge the batteries evenly. You will drain one battery and the batteries will become unbalanced. More charge with go to one and not the other, leading to one boiling dry and expiring and the other going flat.
A Redarc Charge equaliser is a fine piece of equipment and once installed will resolve any 24v/12v issues you have.
If only your car is going to tow the van, swapping the light globes to 24v is an option. You may be able to buy a 24v brake controller - again see Redarc they have a lot of useful stuff for these applicaions- try www.redarc.com.au
You can buy voltage reducers, and may need to for your trailer lights, but they are limited in the current they can draw, whereas with the equaliser you can pull a 50A current from one 12v battery for a while, depending on the battery not the charge equaliser, then when the alternator is charging again, the CE balances the charge between the two batteries at it's maximum Amp capacity for as long as it needs to.
Tim
 Click Image to Enlarge |
| 12H-T on 100% WVO |
Reply 3 of 7
