Site Search
Section Image
Supplying Power to Waeco 80ltr Fridge
Submitted: Wednesday, May 02, 2007 at 13:21
Member - TonyG (Qld)
Hi All,
A mate has just purchased a 80ltr Waeco fridge. He is trying to figure out best way to supply power to the fridge. (I have a 50ltr fridge powered from a dual battery, so I can not talk from experience)
By reading up about the power consumption of this size fridge it appaears to run at approx 3.5amps per hour. (average)
This high power consumption makes me think that a dual battery setup will be no good (ie 110amp hour battery x 80% = 25hrs power supply)
Solar power seems very expensive setup ($1500 - $2000) to pull so much power as well ans recharging a battery for night usage.
Does anyone have any suggestions on best power supply option?
Thanks in advance
TonyG
Enjoying the Outdoors
Click Image to Enlarge
Enjoying the Great Outdoors
Advertisement
ThreadID: 45010 Replies: 5
Views: 953 FollowUps: 1
AnswerID: 237396   Submitted: Wednesday, May 02, 2007 at 13:42
Member - andrew B (Kununurra) replied:
Gday TonyG
I have the 80 litre Waeco, and a dual battery set up with exide extreme's. I have got both 48 and 50 hours with this set up in hot weather, with battery voltage not going under 12. I haven't gone longer without starting the car, but this is about the limit with my setup I think. I also have the fridge very cold when travelling to the destination, and set it a bit hgher when stopped so it doesn't have to cycle for quite some time. I also have a third battery in a box with external terminals for extra supply, but haven't rally put this to the test yet. The theory behind the third battery is that I can charge it in the back of the car via the alternator, and it also is a quick and easy job to set it up as the 2nd battery in my boat, so it can be charged in the boat and be a second battery for safety in the boat.
If you (your mate) plans for extended stays in one place, there are 3 options....solar, generator, and car. All have their ads. and disads, the car option is already available. A bit of a drive for siteseeing every other day may be enough, or spend the cash on the generator or solar, depending on what suits...
Hope this helps a little
Cheers Andrew
Cape Dommet Camping
Daddy/Daughter Camping trip - cape dommett
Reply 1 of 5
FollowupID: 498472   Submitted: Wednesday, May 02, 2007 at 18:15
Member - Ian H (NSW) posted:
I agree with all that as I also have an 80 Waeco. I have dual battery set up but run the fridge only of the deep cycle. I also have a BCS fitted and I get 48 hours from the deep cycle battery.
Contact Fred on (03)97968269 if you are interested. It is a device that limits the on/off cycling to once on and once off each 35 min and the on/off times are adjustable. It works well. About $140 delivered. There are those who PO PO the thing but ignore that. It works.
When you talk you only hear something you already know.
AnswerID: 237397   Submitted: Wednesday, May 02, 2007 at 13:46
hl replied:
It would be more like 2Ah average, depending on outside temp etc. However, you are unlikely to get much more than 2 days without flattening the the battery (except at Perisher or thereabouts) in the next few months. If you are in one place for more than a couple of days, you need either more batteries, a generator or solar panels. Going for a drive helps, but it takes quite a few hours to fully recharge.
Reply 2 of 5
AnswerID: 237405   Submitted: Wednesday, May 02, 2007 at 14:15
Member - Bentaxle replied:
Hi Tony
I running an 80L Engel Fridge/Freezer Combo in a cover on a dual battery setup and have had no problems. Spent 2wks in Karajini, Millstream and Mt Augustus, doin the usual tourist thing and some days vehicle only ran for about 4hrs, plus running lights at night and inverter for laptop and GPS setup, so I can't see your mate having any problems.
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Reply 3 of 5
AnswerID: 237417   Submitted: Wednesday, May 02, 2007 at 14:55
Alloy c/t replied:
We have had our 80lt Waeco for the last 2.5 / 3 yrs ,. used as freezer+fridge as designed , freezer at -15 /18 c = fridge at + 2 / 4c and dairy at 6 / 9 c ,,running thru the Steca regulator we can monitor how many amps used per hr ect ,, over all the time of our use the 80lt at our prefered setting has used 64 amps in ANY 24hr period , the only variation has been when used as all fridge when total power for 24hrs has increased to 72amps.
Reply 4 of 5
Activities Index
Oyster Cove Half Day Kayaking Tour Oyster Cove Half Day Kayaking Tour
Hobart - TAS
Hobart is spoilt by having some of the world's best sea kayaking at its doorstep!
Performance Driver Training - Warwick Performance Driver Training - Warwick
Southern Downs - QLD
Ever wanted to drive your own car at unrestricted speeds on one of Australia's best club race circui
"Fun Casino" - Casino Table Hire "Fun Casino" - Casino Table Hire
Melbourne - VIC
Fun Casino's are the most exciting and interactive way to entertain guests at your next function.
WhiteWater World Aqua Max - Annual Pass WhiteWater World Aqua Max - Annual Pass
Gold Coast - QLD
For less than the cost of three days entry you can enjoy unlimited access to the rides, slides, sigh
Book Now - Things To Do
AnswerID: 237457   Submitted: Wednesday, May 02, 2007 at 18:15
Sand Man (SA) replied:
Well, as there wasn't any other criteria as to where/how he is going to use the fridge, the best power supply option is to plug it in to 240 volt AC.
Now if he wishes to run it while driving, a dual battery system is the only practical option.
When camping, the choice is a resonable capacity battery (say 100A/h+)supplemented by a solar panel, or generator, depending on how long he will be stationary. Or, multiple auxilary batteries.
There isn't any other options.
HooRoo !
Reply 5 of 5
