Site Search
Section Image
Terrano II Tyres
Submitted: Wednesday, May 02, 2007 at 18:56
Iwantaterrano
I have tried to do a search, but it brough tup to many posts to go through and I have limited time to read. So I apologise if I am asking an old question.
I am about to purchase a Terrano II 99 model. I was just wondering how large I can go tyre size without losing to much power or gearing, and without rubbing etc.......I plan on getting a lift in the rear and then winding up front bars. Will I be able to fit larger tyres than standard before the lift, or will I need the lift? I was hoping to get to fit. I believe they run 235/70/15's (30 inch?) standard. Am I dreaming about the 32's?
By the way, I love the car it is fantastic to drive and any other info anyone has on them would be appreciated.
Advertisement
ThreadID: 45016 Replies: 5
Views: 552 FollowUps: 1
AnswerID: 237527   Submitted: Wednesday, May 02, 2007 at 20:51
Iwantaterrano replied:
I know they are rare, but surely there is some one out there with some info?
Reply 1 of 5
AnswerID: 237531   Submitted: Wednesday, May 02, 2007 at 20:53
hoyks replied:
I run 30x9.5 R15's. The speedo with the standard tyres is out, but with 30" tyres, it is spot on.
Yoou would probably get away with 31's, but 32" would probably rub at full lock.
Reply 2 of 5
AnswerID: 237532   Submitted: Wednesday, May 02, 2007 at 20:54
Thanks Hoyks,
So I will need the lift for the 32's.
Any other comments on the car regarding issues, good or bad points. It would be appreciated.
Reply 3 of 5
FollowupID: 498584   Submitted: Wednesday, May 02, 2007 at 21:50
Member - Phil G (SA) posted:
Your standard 235/70R15 are 28"
Mt Finke
Click Image to Enlarge
LandCruiser HDJ79
AnswerID: 237537   Submitted: Wednesday, May 02, 2007 at 21:15
hoyks replied:
I don’t know if the lift will be enough as the tyres will probably scrub on full lock and may also scrub if the rear is at full articulation. Probably the best way would be to find an understanding mate that would let you borrow some wheels and try them. They have the same offset as Jackeroos and the older Pajeros if that is any help.
Some resources for you:
Site Link
Site Link
Site Link
Reply 4 of 5
Activities Index
Whole Day Fly Fishing Trips on Kiewa River for 2 Whole Day Fly Fishing Trips on Kiewa River fo
Wine and High Country - VIC
Come and join us, fly fishing for wild-bred trout in the unspoiled mountain streams of Victoria's al
Personal One on One Surfing Lessons Personal One on One Surfing Lessons
Sydney - NSW
Imagine having the opportunity to surf with one of Sydney's most professional surf teachers one on o
Barista Basics Course - Sydney Barista Basics Course - Sydney
Sydney - NSW
Are you passionate about coffee and want to learn how to make really great coffee?
Sunset River Cruise in Paradise Sunset River Cruise in Paradise
Gold Coast - QLD
See Surfers Paradise by twilight during this spectacular 90min pre-dinner sunset river cruise.
Book Now - Things To Do
AnswerID: 237541   Submitted: Wednesday, May 02, 2007 at 21:39
redmeatgrr replied:
hi,
I've got a T II, and looked into this issue a few months ago. I fitted a 32 inch 10.5 old tyre onto the 15 inch rim. It would've probably cleared the front low edge of the mudguard, as the tyre moves inwards, if I had removed the plastic mudflap and sledgehammered the mudguard itself a bit, using brute force.
Mine has more than stock wheel travel built into the back suspension, and the 32 was just a few millimetres shy of the bodywork on full lock up: that was without releasing the swaybar disconnectors.
But that's how it was in my case anyway. Power loss even with 31's is quite noticeable, and for slow work it idles along a bit too fast in first low for my liking.
A good test to measure this is to drive in first high slightly uphill at around 2500 rpm, then quickly lifting your foot off the accelerator and let it slow down to idle speed (around 750) and keep going in first never touching the clutch or the accelerator. If it ever hesitates to collect itself in the process, your torque is way down due to running tyres that are too tall
Reply 5 of 5
