Setting for Waeco 30Ltr
Submitted: Wednesday, May 02, 2007 at 19:46
Rumbler
Hi guys
Just fitted a 30ltr Waeco. I connected it directly to the Aux battery Via some 6mm cable (approx 2/2.5m). I assume I freeze anything beforehand that I intend to carry as frozen & place in bottom. Rest on top of that. What should I put the temp setting at to keep frozen stuff frozen without too much draw off the battery between drives?
Thank again to you all.
Reply By: Vince NSW - Wednesday, May 02, 2007 at 19:53
Hi Rumble,
With my Waeco, if I set above 3, everything ends up frozen.
Vince
237487
Follow Up By: Rumbler - Thursday, May 03, 2007 at 13:30
Forgive my ignorance, by "above 3:, do you mean below 3 degrees?
498705
Follow Up By: Rumbler - Thursday, May 03, 2007 at 13:34
Now I'm being confusing everyone, what I meant to say instead of "below 3 degrees" was below minus 3 degrees. Sorry.
498707
Follow Up By: Vince NSW - Thursday, May 03, 2007 at 15:32
My fault. My Waco has a round temp dial. Numbered 0 to 7. 0 is the warmest, 7 the coldest.
If I set dial at above 3 (towards 4) I get frozen bee. Not goos at the end of a hot day.
Hope this helps
Vince
498729
Reply By: Member - Olcoolone (SA) - Wednesday, May 02, 2007 at 20:01
Hello Rumbler,
What you may also want to do is get some corflute
sign material and place the frozen stuff on the bottom, then the corflute and then the non frozen stuff.
It all depends where the thermostat sensing tube is.
What model fridge is it?
Regards Richard
237491
Follow Up By: Rumbler - Thursday, May 03, 2007 at 13:37
Thanks, but is "corflute
sign material" that "plastic-coated" corrugated cardboard kinda stuff, the stuff you see in house For Sale signs?
498708
Follow Up By: Olcoolone (SA) - Thursday, May 03, 2007 at 16:20
Thats the stuff.
Can you tell me what model Waeco you are using?
Regards Richard
498740
Follow Up By: Rumbler - Friday, May 04, 2007 at 09:46
Ops! sorry, forgot to say last time. It's a CF/40. Also have in a Waeco bag.
498940
