FollowupID: 498937 Submitted:
Friday, May 04, 2007 at 09:33
Derek from Affordable Batteries & Radiators posted:
Hi Gronk
Features:
* 0~50amp charge rate, you can set different charge rate according to the battery capacity.
* Short circuit and over voltage protected.
* Super
bright LED amp meter display, for charging indication.
* Lightweight, weighing only 14kg.
* High current Leads, 3m long with alligator clamps.
Ideal uses:
* Farmers can supply enough charge in as little as 5minutes to start machinery.
* Campers can run car fridges for 24 hours and charge their batteries in as little as 1 hour.
* 12 Volt lighting or other appliances can be powered in emergency situations.
* Ideal for the marine industry, backup for solar powered sites, emergency services, electromotion
earthmoving contractors, mobile mechanics, or anyone working in the outback.
Technical specifications
Model
SW50A
DC voltage (V)
12
DC current (A)
0~50
Max voltage (Low) (V)
14.5
Max voltage (High) (V)
15.5
Voltage cut out (V)
18
Rated speed (rpm)
5500
Fuel tank capacity (L)
2.6
Continuous running time (hr)
4.0 (at rated load)
Noise level dB(A)/7m
60~65 (zero load~full load)
Dimension (L×W×H)(mm)
402×255×305
Packing size (L×W×H)(mm)
480×275×430
Net/Gross weight (kg)
14/16
Engine model
GS143F
Engine type
Single cylinder, 4-stroke, OHV
Displacement (cc)
53.5
Rated power kW (HP)
1.3 (1.77)
Rated speed (rpm)
5500
Ignition system
T.C.I.
Starting system
Recoil starter
Fuel type
Automotive unleaded gasoline
Fuel consumption (g/KW*h)
420
Lube oil
SAE15W40 (above CC grade)
Low oil pressure alarm system
With
Option colour
Red
 | ABR - SIDEWINDER |
