Winch Size
Submitted: Thursday, May 03, 2007 at 11:40
Teabag (Queanbeyan)
Guy's,
Intend on fitting a Winch to the standard Nissan Steel Bullbar. What is the Largest size winch that will fit the bar without modification with brand and model? Also what is the largest with simple modification again brand and model? I have recieved conflicting info from various 4wd shops......
Thanks in Advance....
Reply By: Time - Thursday, May 03, 2007 at 12:12
Have a word with Ritchie at Hume Offroad, he is also ACT Winch
Services, he'll be able to answer just about everything you need to know to make a decision.
237636
Reply By: Leroy - Thursday, May 03, 2007 at 13:22
The largest will be a 9500lb chinese like TJM, Repco, Ironman etc. 10,000lb are physically too large and from memory the warn 9500 xp's are too long but I'll stand corrected on that one.
Leroy
237645
Follow Up By: Voxson - Thursday, May 03, 2007 at 13:56
XD9000 Warn fitted on my steel Nisan bar but i had to mount it upside down..
The winch that is ,,, not the bullbar...lol...
Made no difference though,,, but make sure the drain holes are sealed up and new ones are redrilled ..
9500XP was toooooooooo lonnnnnnnngggggggggggggggggg.... Hit the chassis rails..
498713
Follow Up By: Voxson - Thursday, May 03, 2007 at 13:57
On my last GU not this one..
498714
Follow Up By: Tony - Thursday, May 03, 2007 at 15:38
Did you try the spacers that ARB supply to fir 9.5's to their bars?
498732
Follow Up By: Voxson - Saturday, May 05, 2007 at 17:47
No i didnt even knew they existed Tony.
499208
Reply By: greggu - Thursday, May 03, 2007 at 18:12
mate i have the tjm 10,000 electric ox fitted in the std nissan black steel bull bar on a series 4 / 3.0 l td with dual (in fact 3) batts - it does the job but does get hot and cant be run for long periods
see you greg
237702
Follow Up By: tdf - Saturday, May 05, 2007 at 07:59
greggu just curious where did you fit 3rd battery in the patrol
499137
Follow Up By: greggu - Saturday, May 05, 2007 at 11:05
tdf i dont have abs brakes assist in
mine so i fitted on passenger side against the fire wall running across the vehicle i used a battery tray made by phirana for the old 2.8 gu's - cause thats where th 2nd battery used to be fitted in the 2.8 - got the battery tray from tjm for about $150 bit of fiddling about and i use a slightly smaller exide extreme in that tray which is the next size down from the n70z for the patrols as its a bit lighter and a bit smaller
see you greg
499163
