Screaming Belt Or Something When Started Cold
Submitted: Sunday, May 06, 2007 at 09:52
WDR
Any thoughts ? Toyot Kluger - Starting it cold creates a one off scream from belt or something - Could it be starter motor or something else terrible?
I don't trust the dealer - he replaced the airconditioning belt because that was noising and squeaking all of the time. Soon after the "fix" I took it back when it started this and they adjusted tension. Seemed to work for a while now it is getting really bad and only happends when car is cold..
Reason I ask is that they keep asking if it only happend when car is cold - Now the answer to that question is yes, I am just trying to find out whet they are trying to find out by asking that question. What are they fishing for?
Hopes this makes sense
Reply By: Gerhardp1 - Sunday, May 06, 2007 at 09:58
Sounds like they are fishing for a reason why the thing is only squealing when cold.
Maybe it's the tensioner pulley that's causing it.
Maybe you're revving the t!ts off it when you start it cold, causing belt whip and slippage?
They've already replaced the aircon belt because as you say it was noisy all the time, now it's not. Sounds like they fixed that part of it to me.
Help them to help you.......
238181
Reply By: Jimbo 2121 - Sunday, May 06, 2007 at 09:59
Does the alternator run off the same belt? Something could be draining the battery when left for a while (overnight etc) and the alternator may be under a lot of load when you start it up causing the belt to slip, but it should not squeel even under a high load. You could check the battery voltage before starting it cold to confirm this theory.
238182
Reply By: Steve from Top End Explorer Tours - Sunday, May 06, 2007 at 10:09
Hey WDR
No the dealership is not taking the bleep out of you, as my Cruisers do it every morning during the dry season when its cool.
I'm changing all the belts today on my trucks, I guarantee I will have to adjust them more than once to get them bedded in.
To help this I run my trucks for 3 to 5 mins before they go in the morning.
I've also herd that the alternator works hard first thing to bring a tired battery up to charge, not sure about that one.
Cheers Steve.
238186
Follow Up By: Richard W (NSW) - Monday, May 07, 2007 at 07:35
My cruiser does it from time to time as
well, generally when the weather is colder.
499421
Reply By: pjchris - Sunday, May 06, 2007 at 13:08
My Power Steering belt used to do this (Paj). Tightened it up and all good for six months so far....
238207
Reply By: The Watto's - Sunday, May 06, 2007 at 13:33
We had an air con belt wear oujt, replaced it and the car was screaching when started cold before the air con belt was changed. We watched the volt meter gauge on the car and noticed it screached until the needle went to 14 exactly, not just short of 14. So we had the alternator belts changed and all is
well again.
No screaching when cold, or any other time for that matter but it only made the sound when the motor was cold.
Good Luck.
The Watto's.
238213
Reply By: Member - Ruth D (QLD) - Sunday, May 06, 2007 at 14:32
It's a Toyota. Probably the a/c belt or the power steering belt.
Mine does it also.
238225
Reply By: DIO - Sunday, May 06, 2007 at 14:46
If it's not a bearing or something else mechanical, try some Graphite powder rubbed into the tracking surface of the belt. Not too much. Works for me.
238226
Reply By: Wombat - Sunday, May 06, 2007 at 14:46
Have you checked where the cat is?
238227
Follow Up By: Member - lyndon K (SA) - Sunday, May 06, 2007 at 15:09
Maybe there is a WOMBAT under the bonnet??? :)))))))))))
499313
Reply By: KiwiAngler - Sunday, May 06, 2007 at 16:29
Suggest tightening the belt (as per previous postings) and/or putting on a little of the fan belt gunk designed to give it more grip. It is avaiable in either spray on or stick application. Stuff is sticky as but works.
Caution: remember to put the cap back on if u buy the spray on - I forgot and as I was bumping and bashing through the bush one day I heard this psssssssssssssssss - thinking it was a flat I got out expecting a deflaed tire - nothing but could still hear the pssssssssssssss. Tracked it down to the tool box when I opened the box I was greeted with all my
tools covered in a sticky, gooey mess :-(
238242
Reply By: Member - Raymond S (QLD) - Monday, May 07, 2007 at 11:23
A quick simple test to see if it is a belt noise is to spray
water on belts, noise will disappear. The other thing with belts when cold & stiff will squeak for a short time till they warm up. I also agree with other post loose belts that we don't pay enough attention to between periodic service intervals.
238358
Reply By: Member - JohnR (Vic)&Moses - Monday, May 07, 2007 at 13:23
Get some Belt Grip spray. Makes the surfaces a little sticky so they transfer the power better. The stuff we have comes in a green can with belts and pulleys pictured on it.
238381
Reply By: Ozboc - Wednesday, May 09, 2007 at 08:02
As a few others have said -- it will be a slipping belt - Toyota ( actually most other makers ) dont have an easy adjustment for belts - and in the case of alternator belts you often have to use a lever to get tension ( why they dont have a tentioning screw is beyond me)
anyway - best way to test is start your car up -- let it warm up a little ( allow oil to go to upper part of motor -- usually 30 sec or so ) then bring revs up a little 1500 - 2000 rpm -- turn headlights on high beam --- if the squeel gets noticably louder then you will know its the alternator belt ( or belt that runs through the alternator for those cars with 1 belt for all ) This is because the alternator is loading up - If you cant get it to squeel then you may have to drain the battery a little ( leave the head lights on for 5 min without motor running) also a little spray of
water ( fine mist) on the pulley will also make it slip - this simulates an early morning start up where the car may be left outside
So if it is the belt thats slipping - adjust it up ( or have someone do it for you ) then also get a can of beltgrip for added insurance
hope this helps a little
Boc
238755
Reply By: WDR - Wednesday, May 09, 2007 at 22:59
Thanks everyone - greatly appreciated
I have now re-discovered it only occurs when airconditioning is left on overnight. It was cooler for a few days in
Sydney and A/C was not used, hence me thinking it was a new problem.
They have already charged me enough for this new A/C belt, they can have another go at next service, I am not wasting anymore time or petrol going down to dealer in between.
Again my thanks
238969
