80 series handbrake
Submitted: Sunday, May 06, 2007 at 11:21
ThreadID: 45146 Views:3795 Replies:8 FollowUps:3
Hi i have a 80 series and having problems with the handbrake not holding, i fitted a new cable and adjusted it but still not holding properly. Does anyone know how they work. Thanks
Reply By: Steve from Top End Explorer Tours - Sunday, May 06, 2007 at 11:26
Try this
Site Link
Cheers Steve.
AnswerID: 238193
Follow Up By: ashy - Sunday, May 06, 2007 at 11:38
Thanks Steve appreciate your help.
So you run tours, i'm about to start planning a big trip will have to get in contact with you.
Thanks Ashy.
FollowupID: 499294
Reply By: V8Diesel - Sunday, May 06, 2007 at 12:22
I can tell you how they work.
Not very well;-) They are rubbish.
AnswerID: 238200
Follow Up By: Member - Jack - Sunday, May 06, 2007 at 14:24
That's a bit harsh. Mine is fine for securing the wife's handbag.
Jack
FollowupID: 499308
Reply By: hiab - Sunday, May 06, 2007 at 19:09
adjust the handbrake at the wheel before adjusting at the other end.
AnswerID: 238260
Reply By: Member - Davoe (Nullagine) - Sunday, May 06, 2007 at 19:33
yep even if you get it adjusted it will be back to the way it was within weeks/a few months - the utes are the same
AnswerID: 238265
Reply By: Max - Sydney - Sunday, May 06, 2007 at 20:32
I hate drum brakes and the 80s handbrake is a good reminder of why.
As others have said, adjust them correctly at the wheels, then adjust the handbrake end so that it takes 9 clicks to pull up. Every few thou (say when you change the oil) just do a quick nip up at the handbrake end so that you only need 9 clicks again. At major services you need to get back underneath and fiddle with that danged adjuster at the wheel.
Drives you mad but they do hold on real ggod if properly adjusted.
Max
AnswerID: 238274
Reply By: traveller2 - Monday, May 07, 2007 at 08:16
Just NEVER trust them, I know of two vehicles that have been written off when they rolled away while the driver emptied the mailbox!
AnswerID: 238337
Follow Up By: Wazza - (Vic) - Monday, May 07, 2007 at 21:09
Yeah that could happen on my 80 series if it was over about 1° incline. Damn handbrake never worked on this thing.
FollowupID: 499555
Reply By: Drew - Karratha - Monday, May 07, 2007 at 10:20
My sister borrowed my 80 series - woke up the next morning to find that it had rolled out of her drive and had stopped acoss the road, blocking most of it off... (It took her a while before she told me that...)
I put it into first gear low range and turn the engine off when launching he boat.
AnswerID: 238351
Reply By: ross - Monday, May 07, 2007 at 21:48
I put new shoes and cable on my 75 series with rear disc brake. I think its the same as 80 series.
I got some mild relief but not for long. I think the drum radius is maybe worn from previous owner driving with the handbrake on slightly.
Ive completely diassembled and cleaned/oiled them and did it much like the 80scool tech link
Is it possible to get shoes with a thicker lining? I going to do them tomorrow again.
How I hate these things. The hand brake on my 73 series is much more reliable
AnswerID: 238479
