rims
Submitted: Sunday, May 06, 2007 at 14:20
ThreadID: 45150 Views:1999 Replies:6 FollowUps:2
hi guys
just a quickie can anyone tell me if rimms off a 1988 cruiser will fit a 1992 patrol
have the opportunity to get a full set of split rims for nix but they are 300ks' away
long way to fined they dont fit tried my local tyer guys they weren't to sure they
were a bit busy at the time so might go back tomorrow and ask again any help
would be appreciated.
thanks in advance
regards
al
Reply By: Member - Reiner G (QLD) 4124 - Sunday, May 06, 2007 at 14:32
There is a lot of 6 stud rims out there with all sort of off-sets. I would take a front wheel of your car and measure from the rim outside to the backingplate where the wheelnuts go. Then find out what the other rims measure.
That would be the safest way to go about it.
my 2 cents worth anyway
Reiner
AnswerID: 238224
Reply By: Member - DOZER- Sunday, May 06, 2007 at 15:55
No the nissan centre hole is larger, the stud pattern is thesame, and if the rims are aftermarket, they will probably fit, as they make 1 wheel to suit all...but if they are factory yota they wont fit
AnswerID: 238231
Follow Up By: hiab - Sunday, May 06, 2007 at 16:14
nissan wheels will fit toyota, but toyota wheels have smaller hole and wont fit nissan
FollowupID: 499318
Reply By: Alloy c/t - Sunday, May 06, 2007 at 16:16
Simple answer is yes , real answer is NO. , offset is the big deal ,forgotten which but it is the + or - which is the variable ,tojo have a +offset ? and nissan have a - offset ?? so one fits the other at a pinch but not something you want long term.
AnswerID: 238236
Reply By: Member - Phil G (SA) - Sunday, May 06, 2007 at 17:13
Andrew is correct. The centre hole is the issue, and its bigger on the Patrols. I know people who have widened the centre hole a touch with an angle grinder to make the Cruiser splits fit in the Nissan. The offset is a little different - means the track is a bit wider when you put the cruiser splits on the Nissan - seen as a plus by many.
AnswerID: 238249
Reply By: Member - John - Sunday, May 06, 2007 at 18:02
al, I have Toyota rims on my Nissan, didn't have to alter anything. John
John and Jan
AnswerID: 238257
Reply By: Member - Reiner G (QLD) 4124 - Sunday, May 06, 2007 at 22:43
I tried to fit Nissan wheel on my Landcruiser ute 95 mod and they touched the callipers on the front. 80 series didn't fit and Hilux didnt fit.
Centre holes no problem but offset needs to be right...........just been trough this over Easter.
Reiner
AnswerID: 238305
Follow Up By: Member - Phil G (SA) - Monday, May 07, 2007 at 17:08
Thats right - offset problem means you can't fit many nissan wheels to cruisers.
But going the other way is OK, and you get a wider track.
FollowupID: 499500
