Landcruiser Fuel Tank Help
Submitted: Sunday, May 06, 2007 at 23:00
Whistle
I have a 100 series Toyota Landcruiser 1998 build and I have always had problems with the fuel
tank. First started when I thought that the main 95 litre
tank would only take about 73 litres??
Now the
tank has a hole in it. Mechanic states that it is caused by the breather hose blocking and in the Landcruiser, the tanks will be sucked in and thus making them smaller. Which explains the problem I have had.
2 questions. 1. Anyone else heard of the above issue. and 2. anyone have an idea of where to get a new main
tank to replace it and any idea of the cost.
Regards,
Tony
Reply By: hiab - Sunday, May 06, 2007 at 23:54
the wreckers, clean it out with jet fuel a-1. just a finer grade of kero, put a pressure cleaner through it and blow out with air hose. if you can.
238317
Reply By: OtherBrother - Monday, May 07, 2007 at 19:15
In reply to Q1, have seen it an HJ75 ute sub-
tank. Breather in the chassis rail blocked up with dust/sand that got concreted. Lift pump sucked it in and it split along a fold.
The giveaway is the whoossh when undo the filler cap.
I thought that with the wagons (HJ60, anyway) the breather was inside the rear quarter panels so blockages would be a rare event.
238429
Reply By: Allan JJ - Monday, May 07, 2007 at 21:46
Also seen a GQ
tank with only a 30 litre capacity after a blocked breather.
A wreckers would be the go, 100 series are not that old so most in the wrecking yards should all be in reasonable condition.
Expect to pay 100 to 200 S/H
Or 500 to 900 new.
238478
